Question about Magellan RoadMate 2000 GPS Receiver
I need to find a replacement external power input part. Not the end that is attached to the charger but the internal part that accepts the charger. I believe thats at fault because just before it gave up you had to apply forward or backwards to the input to get power to the unit.
    President:
  • 1,111 Answers
If your sure you need the power port..skip all the mumbo jumbo at the beginning of my answer and go to the link at the bottom to locate the part.
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
bill
Posted on Aug 01, 2010
Sound
Your TV has a pair of analog RCA Audio Outputs on the back of the set. They are the red and white, female, round outputs and should be labelled as Audio Out. If you have a surround receiver or stereo that accepts this type of input (most do), then you would purchase a stereo RCA audio cable that has the red and white male ends on both ends of the cable and plug them in to the appropriate stereo RCA left and right channel audio inputs on your receiver and the aforementioned outputs on your TV. The same is true if you have a pair of self-powered computer speakers (or similar). If your external speakers or audio systems don't have the RCA inputs, you may need to get an adapter to convert the RCA output to stereo mini-jack (or similar) to match the appropriate input on your external speakers. Does that make sense?
Apr 14, 2014 | Sceptre X322BV HD 32 inch Class Television...
No Power on Hp 620 Laptop
If the battery does not charge then the problem is likely the charger.
If you can borrow a charger instead of buying a new one you can find out for sure if the problem is the inside the laptop its self or the charger.
Remove the battery and hold down the standby button for a whole minute to drain any remaining power in the model. replace the battery , attach the new/borrowed charger lead and see if any activity happens ie, sound, lights...ect. This is the first thing someone does in a repair shop and its to diagnose where the issue is comming from.
Feb 21, 2014 | HP Computers & Internet
Convert Dewalt Charger DE 9116
It is not feasible to convert it internally.
Jul 15, 2013 | Dewalt 7.2-18.0 Volt One Hour Charger
Battery charger
EXTERNAL OR INTERNAL EXTERNAL GET A TRICKLE CHARGER CHARGE MORE THAN 2 AMPS INTERNAL CHECK ALL ALTAERNATOR COMPONETS WIRES ETC. REPLACE AS NEEDED
Jun 23, 2013 | 2002 Honda XR 200
Will not turn on,
Try these.
- Remove battery, press power button for at least 20 seconds. Power on the system using the AC adapter (charger).
- Use another working AC adapter if still no power.
- Make sure that the DC input jack where the AC adapter is inserted to the laptop is not broken, otherwise, replace motherboard.
- If you get power but blank screen, connect an external monitor. If you get display on the external monitor, the LCD needs to be replaced.
- If you get no display on the external monitor, reinsert the memory module/s (RAM), otherwise, the motherboard needs to be replaced.
Hope this helps.
Jul 17, 2011 | Toshiba Satellite L455DS5976 Notebook
Will NOT accept POWER. I have replaced the power supply and still does not power up. Lacie said thet can change it out, but would not guarentee no data loss. ALL I need is a mother board for the d2...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 21, 2011 | LaCie (130742) Serial ATA Controller
I have a pavilion dv 7 that shutdow the otherday.The battery was hot and if i turned the pc back on it would run for a couple minutes then shutdown.The charger was also hot. I purchased a new battery and...
There are isues with HP external power supplies - if it is a dv7-3xxx series you require AC Smart adapter (120 watt) - 100-240VAC input, 50-60Hz, 2.5A - 18.5VDC output, 6.5A, Pt No 463953-001
for earlier models require AC Smart power adapter (90 watt) - 100-240VAC input, 47-63Hz - 19.0VDC output, 4.74A, 90 watts, with power factor correction (PFC) 463955-001
If you are within the warranty period utilize that warranty if not contact HP and see what price a replacement external power pack is.
Jun 15, 2010 | HP Computers & Internet
I am attaching an external microphone and need to mute the internal mic. They both work and it echos. PLease help.
Adding a mike doesn't create echos/feedback. Windows? Version? Right click on speaker icon in lower right and go to recording device mixers, can mute and adjust level of sound sources, also microphone power and pre-amp. Telephones and other devices (laptops) with both input and output will feedback unless the input is "noise cancelling", so you will have to be much more careful with the placement of the external mike compared to using the built in mike.
Oct 14, 2009 | Computers & Internet
Car Power Unit
I'm not sure that there is a car charger available for the GPS 310. There is no external port where you could plug it in, the only thing you can do for power is take extra AA batteries with you.
Jul 02, 2008 | Magellan GPS 310 GPS Receiver
HP iPAQ doesn't turn on
Failed battery pack most likely.
Jul 11, 2017 | HP iPAQ hw6510 Smartphone
Magellan RoadMate 2000 GPS Receiver Logo
61 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
