Question about Sea Gull Lighting 1555-734 Three-Light Cypress Grecian Stone Ceiling Fan
I have an older Moss ceiling fan/light that the fan switch is bad. I went to replace it and found that they do not have a 6 wire switch and only sell 4 wire. How do I convert, I do not want to replace the unit when it is in working conditon otherwise.
Why Ceiling Fan Fixture does not work
You get what you pay for! Shouldn't buy a store brand.
Jul 14, 2014 | Hunter 52" Ceiling Fan With Light And...
Why my Hunter Ceiling Fan does not work?
Its unlikely that the fan is on a separate feed from the breaker box than the rest of the outlets in your room but you never know. It would not hurt to check all of your breakers. If the fan and its light are controlled by the same wall switch then the wall switch may have went bad. Within the fan there are separate wires for the fan and the light so both of them would not go out at the same time. It makes more sense that the problem is at your wall switch.
Jul 14, 2014 | Hunter 25872 Sojourn II Brushed Chrome...
Harbor Breeze ceiling fan lights won't work
Check light wire in ceiling to make sure it didn't come loose.
Jun 06, 2013 | Dryers
I have a westinghuse fan with light it has four wires on it green, blue, black, and red what are they ie live neutral etc
Question posted under 3-speed switch
1) Are you replacing the 3-speed switch?
This is a field with much discussion because Westinghouse 4-wire fan switches vary.
Process of elimination is needed to find hot line. From there you test each wire to the hot line wire to determine which wire or combination of wires makes up low, medium, and high speed.
Open following links for some resources:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php
http://www.atlantalightbulbs.com/ecart/catalog/westinghouse-6.html
2) Or are you looking at fan connection wiring at ceiling?
Green wire goes to bare ground.
Fan should have hot and neutral.
Hot line should be black.
Neutral should be white.
Red usually goes to light
Blue is normally not there.
Where is the white neutral wire?
Take multimeter set to read ohms and test black wire to each other wire.
Process of elimination should reveal correct wiring.
Aug 21, 2011 | Speed Ceiling Fan 3-speed Switch By...
Chain broke on jin you 3 speed 5 wire switch part # 70469. only repacement found has 4 wires. any known suppiers in the Orlando,Fl. area?
Try following link, without guarantee: It has same number but says 4 wires
http://www.allelectronics.com/make-a-store/item/PSW-14/PULL-CHAIN-SWITCH/1.html
You posted under Westinghouse:
Internet search does not show 5-wire switch, they are either 3 or 4 wire.
Maybe you have older fan, or maybe the switch can be replaced with 4 wire.
Next step would be to test your wires to see if 4-wire conversion can be made:
Determine which wire is hot if possible.
Take photo of wires and then remove switch.
Use multimeter set to read ohms, and test between each wire and the wire you labeled hot wire.
Aug 02, 2011 | Westinghouse Electric Westinghouse...
Hello, I replaced a light fixture on my existing Emerson ceiling fan. The light worked right away but the blades didn't turn. I could hear power going to the motor so I went back into the switch cup and...
Signs of a bad capacitor in a ceiling fan include:
  • Fan runs slowly or not at all on all speeds
  • Fan will not start but will spin if started by hand
  • Certain speeds are slow or do not work
  • The motor hums and turns freely by hand but will not spin
    The capacitor is usually a black box inside the switch housing of the fan. If this box appears burnt or melted in any way, that is also the sign of a bad capacitor and it should be replaced.
    have a good day !!
  • Feb 17, 2011 | Emerson Fans CF705AW 52" Northwind Ceiling
    3-speed fan switch broke on Hunter model 28072, cat. 300 fan. Found replacement switch at Lowes, but wiring colors are completely different from manual. What color wires go into L, 1, 2, 3 positions...
    My Hunter fan uses a Zing-Ear ZE-268S6 switch. This is NOT a standard switch! It connects L to 2 AND 3 for medium speed. It is best to order the exact switch if possible. Hunter wants to sell you the entire bottom assembly (probably expensive). I found the exact switch online at:
    http://www.kenselectronics.com/lists/switches.htm#Pull%20chain
    for $6.80 plus $4.95 shipping. I bought an extra which didn't increase the shipping - worked great. Hunter ZE-268S6 ceiling fan connection colors: L=black; 3=green; 1=grey; 2=brown. If you need a different switch on their page, just click the Edit menu, then Find, type your part number in the box, and click Next.
    Nov 30, 2010 | Hunter Ceiling Fan Control Switch
    Replace ceiling fan light switch
    mcdevito75 here, How was the old switch hooked up.
    Jul 23, 2010 | Hunter Ceiling Fan Control Switch
    I have a hampton bay ceiling fan which will only run on the fast speed. I have changed switches but still only the fast speed. I have touched each wire to the load wire to see if it was the swith but no...
    Hello Brother,
    Installation:
    Hang your ceiling fan on the Quick Connect fan bracket and wire the ceiling fan according to the manufacturer's instructions. The three wires coming from your ceiling should match the three wires coming from your ceiling fan: black (positive or hot), white (neutral or negative) and green (ground wire).
    Use the high, medium and low keys on the remote to adjust the Hampton Bay fan speed, then use the light key to dim the light and the off key to turn off the fan.
    For REMOTE CONTROL FANS you cannot use with any variable speed or slide wall switches. The remote control function must be used with on & off switch outlets only.
    Speed Controls Click here Capacitors Link
    I hope This Helped you,Thanks for Contacting FixYa...
    Apr 22, 2010 | Hampton Bay Heating & Cooling
    Sea Gull Lighting 1555-734 Three-Light Cypress Grecian Stone Ceiling Fan Logo
    Top Sea Gull Lighting Dryers Experts
    Marvin
    Marvin
    Are you a Sea Gull Lighting Dryer Expert? Answer questions, earn points and help others
