Question about Coleman Sport 1850 Generator
I have a Coleman generator 1850 pulse and it runs ok for a little
I have a Coleman generator 1850 pulse and it runs fine for about ten minutes. Then I start seeing air bubbles in the fuel line and then it starts missing. After that it dies because there is no fuel in the line. Then about a minute or so the line fills up with gas then it will start again. I have cleaned the carb about 5 times now and it keeps doing the same thing. Any ideas? TIA
    President:
  • Coleman Master
  • 1,388 Answers
Gravity feed fuel systems are the most simple and reliable way to deliver fuel to the engine, however suffer from a couple of problems.. As the engine heats up fuel tends to be pushed out of the carb back into the fuel tank and if the vent in the gas cap is not working properly fuel lock (or a slight vacuum in the tank) will prevent fuel from entering the carb. There should be a plastic block or manafold seperating the carb from the engine to keep the carb from overheating. Some engines have this block bolted to the engine, then the carb bolted to block., others have two bolts thru the carb and block to engine. In ether case make sure parts are held tightly together so no vacuum leaks thru gaskets.. One should make sure that the gas cap is venting. Sometimes fuel sloshing in the tank will clog the vent-hole in the cap. Try running the generator with the cap loose to see if this helps.. Replace fuel cap as needed if vent is clogged. Good luck with your generator.
Posted on Jul 30, 2010
My older Coleman Powermate Pulse 1850 is leaking gas from the grommet that connects the hose to the tank. I cannot get needle nose plyers inside the tank to tighten the nut (if there even IS a threaded nut...
I don't think there is any way to tighten or repair leak other then by replacing grommet. sorry I'm not much help but coleman powermate is no longer in business and I have had no sucess in finding a source for parts for you.Thank you and good luck.
Feb 24, 2011 | Coleman 1850 Watts Generator Each...
I have a coleman powermate pulse 1800ex generator. It stutters when put in the run position. when in the choke position it doesnt stutter.
your main jet is plugged shut off fuel, remove bowl from carb(bottom of bowl) clean out small holes on screw with stranded wire .2 holes on side on in middle. be sure to put fiber washer back between main jet and bowl and use fresh gas jor
Jan 11, 2011 | Coleman 1850 Watts Generator Each...
Coleman 1850sport plus when running pulses up and down it will only run properly with the choke half on and when shut off gas drains from carb, have cleaned carb three times no success help
double check the float ajustment and replace the needle valve for the float carb should be rebuilt kist run around $20.00 and the float about $6.00+ ajust the carb.
hope this helps
Sep 01, 2010 | Coleman Sport 1850 Generator
Coleman sport 1850 powermate generator, no fire to sparkplug
is there an oilprotection on the gen. disconnect the cable and try again
Jan 18, 2010 | Coleman Sport 1850 Generator
Engine speed varies
If the unit was stored for a long period of time (6-12 mo.) with gas in it, you may have a gummed up carburator. This is the most common problem with generators (lack of use)
The carb. would have to be removed & cleaned, specificly, the high & low speed jets
Sep 04, 2009 | Coleman Sport 1850 Generator
Need manual for coleman powermate 1850 generator
google it! use the specific search terms, Coleman power pulse 1850 - it worked for me!
Jun 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Pull start recoil assembly
I bought a replacement recoil starter for my 1850 at Pats small engine parts. The part number for a 3.5 B & S is 499706. If you look on the heat shield on the side of the motor there is the engine model and s/n. Hope this helps.
May 31, 2009 | Coleman Powermate Powermate 5000W...
I have a Coleman Powermate Pulse 1850 Generator.
If the generator hasn't been used for awhile the rotor may have lost it's magnetism. All you need is to re-excite it. There are several websites that explain how to do this. It's a good place to start.
Erick
Mar 23, 2009 | Coleman Electrical Supplies
Generator will not start
You say there is compression .What was the p.s.i. on the gauge. If below 100 p.s.i.. May have bad ring, valve out of adjustment or bad head gasket. Is there spark and what does spark plug look good, is gap ok . Is the fuel tuned on and kill switch on. Will need more info to help out more.
Mar 15, 2009 | Coleman Sport 1850 Generator
Coleman Sport 1850 Generator Logo
574 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
