Question about Toshiba 50HDX82 50" Rear Projection Television
It only runs for 15 mins or so then the poicture and sound goes off, If I unplug it for a while it will come on and do the same. Main board I think.
    Problem Solver:
  • 11 Answers
Main board it is
Posted on Jul 29, 2010
Testimonial: "thanks for the help, now how do find the board..."
  • AJbezares Jul 30, 2010
    well you will have to unscrew the tv of course. The board with all of the input connections like the hdmi/component/av. Thats the main board
Comes on fine, good picture and sound. After about 15min. sound stays on but picture goes black
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jan 27, 2016 | Syntax Olevia Lt30hv 30-inch Hd-ready...
I have a dell inspiron 530 with the quad core an everytime i start it up it goes into windows for about 10-15 mins an the monitor screen just goes blank an the keyboard lights go off an when i push the...
it sounds like your motherboard is shutting itself off to protect itself from overheating or some other system failure. you should verify all your fans are running at the correct speed. if it seems like everything is running fine, you can probably turn that off in bios. obviously if there is something wrong with the fans, then you need to replace them. Another options is maybe the processor is getting too hot which is why it's shutting down. open the case and remove the heat sync from the board so you can see the processor. clean the thermal paste off the processor and apply a new generous layer. put the heat sync back on and then try and restart. make sure before you do ANY of this you unplug the computer! good luck and let me know if it works!
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jan 27, 2012 | Dell Inspiron 530 Desktop Computer
Refrig is running, but freezer defrosted and food side seems to be getting warm. Always blew warm air from bottom front, now just cold air.
Sounds like the compressor is not running. Try unplugging for 15 min. to allow compressor to reset. If you hear a clicking noise you may have a bad main board.
Feb 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Picture goes black mins after watching
Bad flyback transformer. It has a short in the winding making the Horizontal output transistor heat up so when its too hot the set goes into protection.
Aug 25, 2009 | RCA D52W23 52" HDTV CRT TV
Amplifier goes open after operating for 15 - 20 minutes, no sound
HI...
It's probably a solder joint that's intermittant. I see a lot of these in my work.
Have a tech with good eyesight give the main circuit boards a once-over for solder joints that dont look right.
Apr 10, 2009 | Technics Audio Players & Recorders
Plays for 10-15 min.then pic.goes black,sounds stays on.
Resolder FBT pinns flyback transfomer on deflection board also CK capacitors 3 of them cp114,120,150 if anmy of them is puffewd up on top it is bad.cp150 2200uf 16v other 2 are 220uf 35v replace all 3.
Jan 28, 2009 | RCA R52WH73 Projection Television
Hot to adjust the convergence on the DP6155
resolder the fingers on the edge of the power supply where it goes into the main board edge connector.
Oct 16, 2007 | InFocus Proxima DP6155 Multimedia...
Toshiba 50HDX82 50" Rear Projection Television Logo
53 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
