Question about Jl Audio Class D E1400D Car Audio Amplifier
Hit bump and subs and amp wont work
My system was working fine and then i hit a bump and noticed my subs were out. ive checked all connections and they are good. when i turn the radio on the amp gets power and immediately shuts off. i figured it was the ground and when i push on it i get crackles and pops but no sound.
  • silverado4me Aug 01, 2010
    power and remote wire are good so i opened up the amp (JL e1400D) and only one LED (d2) is lit up out of the total 10 (including the exterior power light. would this be a fuse or something?
    Guru:
  • 632 Answers
Loose wire or connection is causing stereo to short out, Check all connections including amp,Stereo,Speakers and make sure nothing is touching places it shouldn't
Posted on Jul 31, 2010
  • Simon Swales
    Simon Swales Aug 16, 2010
    Is ground wire good, and located in a good place, if not will not function correctly.
My 2003 grand am gt , has monsoon stereo , the stereo seems to be working fine , but there is no sound coming from the speakers , ive put new transmisson in it two years ago and ever sence that the stereo...
If bumps affect the noise then you should be looking at loose wires and connections for the speakers and at the back of the system. Look for a bad earth or the earth wire connected up to something that is not really a good earth
Jan 12, 2014 | 2003 Pontiac Grand Am
Hi i need some help i have a sub and amp in a ford fiesta 2001. ive chanced cd players to a ridspeed dv720. my sub was working fine with my old cd player but now ive put the ripspeed in it doesnt work. i...
You can use a "Y" cable to combine the two RCA cables to the one out. You will need a 1 male to 2 male cable. That will solve the signal problem. Is the amp functioning properly. I would check that first. Make sure your wiring is correct. Hope this helps
Aug 25, 2011 | Car Audio & Video
My subs will not hit when my trunk is closed
just like a speaker system they don't work in a closed box it has to be vented, and you trunk is too well sealed you need to incorporate ports
May 11, 2010 | Car Audio & Video
Alpine type-r 2ohm dual voice coil help
try reconnecting your rca's from the deck to the amp when finished wire one speaker positive to positive on left channel and negative to negative on right channel then connect the 1st subwoofer. if all power and sound is fine and working turn off power to amp and connect negative terminal of 1st sub to positive on 2nd sub and positive from first sub to negative on second crossing the wires runs the speakers in series another way to try is parralel the speakers wiring by connecting positive left channel output of amp to positive on 1st sub same with the negative then splice positive to positive on second sub and same with negative.
Feb 09, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Kickers dont beat like they should
try to check and clean the wiring as clean as possible to avoid messing up on your connection. Check the polarity of you subs to yuor amp if you have it connected on the outher way around it would not give you a good result. check the polarity this will solve your problem. Over powering your sub will fry it easily try to tune it a 10" sub wont give you a 15" performance..
Jan 20, 2009 | Jl Audio 500/1 Car Audio Amplifier
Subs dont beat like they should
you've spent alot of money on **** by the sounds of it!!. you should only ever run multiple subs the same brand, power and resistance you can just connect any old subs to a system you need to wire them depending on the load that the amp needs to see. first thing is to try the amp/s on a individual sub to check your amps still work once done check the subs 1 by 1.
Deck, Sub and Amp Problems
check for any loose connections at the fuse block or a loose fuse
using an ohm meter would help
check the harness on the back of the radio for loose connection
bad igntion switch, again an ohm meter would help !
what type vehicle ?
Jan 13, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Amp does not power on, flickers when cable disconnected.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is too low.
Dec 05, 2007 | Car Audio & Video
Spontaneously shorted, now blowing fuses on amp too.
Time to go to the repair shop. Sounds like you have a blown amp. Good luck.
Feb 22, 2007 | Rockford Fosgate Punch P4004 Car Audio...
Car Audio & Video Logo
252 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
hoyzee1
Morne Olivier
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
