Question about Emerson EWL20S5 20 in. EDTV-Ready LCD Television
Tv automatically shuts off after being on for a few seconds EWL20S5
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 132 Answers
The most common problem for this set that will cause shutdown after a few seconds is the inverter board. Looking at the set from the back, it is the long slim board that is normally located on the far left side of most lcd tv's. There are 3 electrolytic capacitors located on this board, and changing them will fix a lot of these sets for this problem. The location numbers of the caps are c330, c350, and c370. If you have any experience working on electronics, I would start by changing these caps. They are very inexpensive. If you would rather just change the inverter board, try shopjimmy.com. That is a good place to buy boards for flat screen tvs.
Posted on Jul 29, 2010
2 Suggested Answers
SOURCE: Emerson EWL20S5 20 in.
This TV has a network of diodes connected to a PROTECT-1 line monitored by the control IC. If any circuit pulls this line low, the control IC turns the system OFF. The diodes act to isolate all the circuits from each other, its called a diode-OR circuit.
You can troubleshoot by opening a diode which disconnects a circuit from pulling the line low. I had a hunch the EL backlight board was bad, so after opening that protect line the power stayed ON.
I found a bad .068uF 250V cap on the transformer primary, it measured .002uF. I've replaced the cap and the other two on the other transformers just for good measure.
It probably took more time than the TV is worth, but my friend's Mom will be happy, and thats worth it.
I hope this helps, look around for the service manual, it can be found online.
Posted on Jan 15, 2008
Pairig tv EWL20S5 C
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 01, 2016 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Is emerson ewl20s5 tv digital or do I need a converter box?
The set can recieve analogue transmissions or cable signal only, for digital transmission a converter box would be needed
Mar 05, 2011 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
TV will not stay powered up. The light comes on for a second, then powers off again.
you have a bad transfomer on your inverter board you need a tech to find which one or just replace the board
Sep 24, 2009 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Emerson tv goes off after a few seconds
The shutdown is probably caused by the power supply, although it may not be at fault, just trying to prevent a fire.
There may be other circuitry that is failing and drawing excessive current and most supplies are designed to turn off if the current drawn exceeds a certain maximum.
This is not a problem you can solve without technical skills.
Jul 06, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Emerson 20" lcd
bad power board or bad capacitors on the power board service required
May 27, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Parts for EWL20S5
By chance does it use the same type of cord as a computer or monitor? These cords can be found at local Radio Shacks, or if you live near a business which has a number of computers, and upgrades machines regularly, they might have extra cords lying around in their closet.
Otherwise, take a pic of the connection on the TV, take it to Radio Shack, and make a match there.
You could look in the TV's documentation- maybe get help there too.
Apr 14, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Prolbem
how old is tv?? and the best way to see if its the power botton is to try and hold for a few seconds and if it don't stay powered on then unplug and replug .....other then that sounds like power supply
Apr 01, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Ok, my tv was doing the exact same thing. What turned out to be wrong was one of the florescent backlight bulbs was broken. The tv was given to me, so I'm not sure how it got broken, but replacing the bulb repaired the tv.
This is not an extremely hard repair, but you have to be careful.Doing this repair entails disassembling the entire screen assembly. If you have any doubt at all about doing it, get a pro (like me). Getting a new bulb was not hard for me because I have several of these units in my shop with bad LCD screens; it may be a little harder for the general public.
I hope this helps.
Steve Wright.
Oct 24, 2007 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Aug 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Emerson EWL20S5 20 in. EDTV-Ready LCD Television Logo
1,048 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
