Question about Nordic Track NordicTrack Treadmill, A2550
My nordictrack a2250 only beeps when i press a command and nothing happens
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
The console software is damaged and the console will need replaced
Posted on Aug 11, 2010
  • 2 more comments
  • spamslisher Oct 31, 2010
    I had the same problem with my Nordic track. I pressed every button until I found the one that did not beep. The one that does not beep is stuck. My problem was with the Ifit button. I disconnected the unit and now the thing work fine except for Ifit which I never used. Nordic track wanted to cell me a new console which cost more than the machine.
  • Jinfu Nov 27, 2011
    Great answer from Jim!
    That is exactly the problem I have! my model is C2500. very easy to disconnect the iFit unit.
    Sorry, I meant great answer from spamslisher, not Jim. the console doesn't need to be replaced.
  • Satya Hota May 20, 2012
    I have a A2250 and it is beeping. I like the answer from spamslicesher but do not know how to disconnect the console. Can anyone explain me how to do it? Again, how does the unit works with the console being disconnected?
    SRH
My NordicTrack A2250 treadmill display is flickering. The unit runs perfectly well. Can this be repaired?
Hey Alfred, yes it can be repaired,,, but in the interest of saving $$$$,, if it runs... just jump on and go until you have had enough... the rest is really trivial..think about it..
Jul 12, 2017 | NordicTrack Exercise & Fitness
The light on my panel is very dim. Does it require battery replacement? if so where are the batteries located on this model?
There is a manual here which doesn't mention a battery, but I am sure I see what looks like a battery cover with a single screw under the console. I also see other posts which state 'lift the console and replace with fresh batteries'.
PDF]View Manual in PDF Format - NordicTrack https://service.nordictrack.com/CustomerService/pdfDownload.do?... this manual and order part number 146148, or ... tem is damaged, the walking belt may change speed ... ercising, the unique A2250 treadmill can be folded up,.
Dec 28, 2015 | Nordic Track Nordictrack A2250 Console For...
Have a nordictract a2250 the lights come on on the dash but nothing turn on just light up after you touch any button it's beep 3 x
I have a 2500 and had a similar problem, console lit up but no functions. I followed the suggestions on other boards and unplugged the iFit cable from the main board. Works just fine now. To do so, you have to remove 10-12 screw from the underside and then trace the ribbon cable back to the board and wiggle it out.
Oct 30, 2013 | Nordic Track NordicTrack Treadmill, A2550
When I plug my Nordictrack A2250 in the fan runs and the screen is blue, none of the buttons work. This is without the safety pin attached.
Adjust the REED switch, test it, clean it, and tight the plug or connector very well.
2) replace batteries with the same type, same mark, same polarity
3)clean contacts spring with c. cleaner spray. buy it from some electronic store.
God bless you
Nov 29, 2012 | Nordic Track Nodictrack A2250 Console...
Nordictrac a2250 beeps when key is attached
adjust the reed switch first, and after RUN the software calibration for diagnose and troubleshooting. see the diagram
God bless you
Jun 17, 2012 | Nordic Track NordicTrack Treadmill, A2550
I have a nordictrack a2250 when run on it the belt slips i need to tighten the belt
If your treadmill has had a lot of use, the belt has probably stretched and needs replacing. You can order a new one at Treadmill Parts
Nov 07, 2010 | Nordic Track NordicTrack Treadmill, A2550
Incline goes up and down
I had the SAME problem, several time, with my NordicTrack A2250 Treadmill.
Allow it to go fully up and then fully down several times, without turning it off. IT seems to "cycle" that way 3 times and then "reboots" itself and starts working normally, again.
I had to figure this out myself... none of the suggestions I read worked.
Apr 24, 2010 | Nordic Track NordicTrack Treadmill, A2550
I have a NordicTrack A2250, about 2 years old. When it's turned on, the control panel lights up, and when I insert a program chip, the console "speaks". However, the neither the incline nor the belt...
Will the treadmill work when the chip is not plugged in, or does it just beep every time you select a button? If so, your problem is easy to solve. The board that supports the two adjacent up and down buttons has slipped. To fix, you'll need to remove the panel and remove the 3-inch retaining bar which is held in my two screws. Realign the board so the buttons are free to move in the available slots. Good luck.
Dec 05, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack Treadmill, A2550 Logo
1,183 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
