Question about Car Audio & Video
Apparent intermittent ground on dash lighting
2 days ago started to experience blinking of dash lighting, i.e., main console, climate control, radio, clock, cig. lighter back light, and overhead mpg indicator. When headlights turned on, above lighting will start blinking in no fixed pattern. With headlight switch off - no problems. Dimmer switch postion has no effect on problem. Can you point me in the right direction to start troubleshooting or would it be better to have a ford dealer check it out without going bankrupt in the process.
My best advice to you is to go and get a new alternator because thats what the problem is.
Posted on Sep 11, 2008
Digital Cluster Dash AND Climate Controls intermittently go out at the same time?
This could be a ground bus connection that is bad. You have to take the whole panel out again and trace wires to see where the ground bus connection is .
May 08, 2015 | 1991 Buick Riviera
Intermittent dash board problems
sounds like you have a grounding issue possibly a main grounding location. inconsistant grounding of the vehicles control module will cause erratic behaviours. check under the hood for ground locations containing multiple grounds at 1 bolt location.if different "experts" have attempted repair and failed chances are they are all looking in the wrong place.dash{interior of vehicle}..actual cause.{egine compartment or under side of locations.}good luck and safe motoring:>
Dec 22, 2013 | 2005 Audi A3
Odometer won't work unless headlights turned off, radio lights dim, blinker won't blink all the time now battery light comes on but battery tests good. Intermittent issues getting worse. Horn
You probably have a bad ground in the electronic instrument cluster, or cluster connection to wiring harness. I would recomend you have a qualified auto tech diagnose it. It is not a easy fix.
Mar 16, 2013 | 2000 Ford Expedition
Lack of power, hesitation, climate control blowing hot air
Always check body grounds. You may have good power to the engine with a good ground still, but your body grounds control power to all else.
May 03, 2017 | 2006 Lincoln Mark LT
Turned key..nothing happened, dead, no dash lights interior lights or mileage, released hood button, dash instruments came on, turned key car started..while driving radio goes on and off as well as the...
Check ALL Power and Ground connections coming off the Battery to circuit anchor points. Ignition and Services fuses for a Power supply. If all proves ok, then go to the Main Ignition control Relay and check the condition of the Pins and Recepticles. That is where your apparent problem may eventually be. But travel the initial route first, looking and feeling for Loose or Dirty connecting points.
Regards, David
Nov 28, 2010 | 2006 Chrysler Sebring
REPLACEABLE? dash, radio, climate control dash lights, 96 C-1500
yes they are they take the miniture bulbs to replace them you must remove the four screws holding them on from the back side 5/16ths to get them off then slide out and allow to drop down follow wires and twist sockets out to remoce aocket and replace bulbs, ther are 4 bulbs in the dash console for ac and heat.
Apr 11, 2010 | 1996 Chevrolet C1500
My dash lights and radio lights blink from bright
It sounds like a poor Ground connection, Start by checking the connector that connects to the Instrument Cluster then see if one wire is terminated to the Metal components of the Dash Board. This would be the Master Ground connection for ALL Instrument lights and typically would include any other Lights on the Same Circuit. You will most likely find a loose sheet metal screw making this Ground Connection. With a high resistance connection the lights would be somewhat dim. If they flash between Dim and Bright it is an intermittent connection causing it. Almost always this will be found to be a loose screw connecting the Ground to the Chassis.
Dec 07, 2009 | 2006 Jeep Commander
2001 Jimmy. Speakers don't work/ Heat stuck on High
hot cold selector switch bad sound like it needs replaced
Feb 17, 2009 | 2001 GMC Jimmy
Intermittent instrument, radio, and climate center lights
check the fuse box and under hood ,check one by one with the climate control on and radio lights on , and you will see when the radio its off or on.
Dec 16, 2008 | 1998 Buick LeSabre
BMW 328i convertable climate control intermittant problem
I have a 318i and my climate control is faulty one sec it will be on then it shuts off then it may or may not come back on. and i noticed around the time that started happening my right blinker would start flicking erratically. just hoping for a little info.
Nov 28, 2008 | 1997 BMW 328
Car Audio & Video Logo
62 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
