Have Kenmore model 110.47511700 and have fail code F01 what is that?
3 Suggested Answers
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
mgprice
  • 744 Answers
SOURCE: Washer won't start. Error code f01 shows.
Hi F1 means your CCU is bad and needs to be replaced sorry :( If you have any other questions please feel free to comment again. Mike e63dqt.jpg
Posted on Nov 19, 2009
  • 6277 Answers
SOURCE: Kenmore Model 110 47532602 Front
Have you checked the drain motor/ filter?
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 10, 2011
Kenmore elite he5t washer model 11047789701 flashing F01 fault code- does this mean ccu must be replaced?
Do not take this as definitive answer! I am not an expert. A F01 error is indicative that the Central Control Unit cannot get instructions from the EEPROM. If you have not already done so, unplug the washer for a full 2 minutes to clear any instructions in memory, then plug it back in. If you still have a F01 error I suspicion that it is a bad CCU board. You can try to run the diagnostic on page 8 of the service manual but I do not think it will run if it is a bad CCU board.
Mar 08, 2015 | Kenmore Elite HE5t Washer
110.4753 error code f01
I found this on the WEB-In reference to your Kenmore HE washer, model number 110.4753:
F-01 Error code
EEPROM ERROR
PUMP DRIVE ERROR
, or a
MAIN RELAY ERROR
EEPROM ERROR
: A communication error between the
(CCU) and the
EEPROM
onboard the
CCU
occurred.
PUMP DRIVE ERROR
: The pump driver fails to operate
MAIN RELAY ERROR
: One of the main relays is not working properly
Mar 31, 2014 | Kenmore HE2 Plus Front Load Washer
KENMORE HE2 F01 CODE
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
http://media.fotki.com/1_p,wkwdffkrdwtbgwsxgtqsskgwtqkq,vi/ksskgsfwrxksrttqdqr/1/1303472/5961857/image12923img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 30, 2010 | Kenmore HE2 Plus Front Load Washer
Error code F01 on Kenmore front loading automatic washer - Machine will not start. Who do you call to have machince serviced I live in Saskatoon, SK Canada
Aug 08, 2010 | Kenmore HE2 Plus Front Load Washer
I have a F01 code
The F01 fault code is indicating an EEPROM error or a PUMP DRIVER error. A communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Possible causes of an EEPROM error:
A power glitch may have caused this error. Unplug the power cord for 3 minutes then reconnect power.
Possible causes of PUMP DRIVER error:
The pump driver fails to activate. Replace the the CCU board.
Most likely the CCU board will need to be replaced.
Apr 13, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore elite f1 code any one know what it means
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
F1 error on Kenmore he2 plus model 4619790225122
Feb 09, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore Model 110.47561602 - HE2T. The drain
Oct 13, 2009 | Kenmore Washing Machines
My front load he2 washer model # 11047561601 won't start it has a error code that says f01
Oct 10, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE washer gives error F01. What can I do?
Apr 07, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
