Question about Protron PLTV-32 Television
The light at the front of my protron tv is red and
My tv will not turn on but the light on the front is glowing red... Any ideas?
  • 11,361 Answers
Check the AC adapter voltages first, it should put out 12vdc and 24vdc, the 12vdc is working because the light in the front panel light up, You may have problem inside if you do have both voltages. Report back what you find first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Jul 30, 2010
Protron 32"LCD TV won't turn on. Red light is on. Help!
Hi Annette,
Please consult some local TV Tech because fixing this TV will need opening it and then diagnosing the fault.
Aug 08, 2015 | Protron Televison & Video
Replaced lamp on mitsubishi wd62527 worked for 10 minutes then shut down. Now red lamp light is on
If the red indicator light on the front of your HDTV is glowing a solid red, you should first unplug the AC cord from the wall power outlet and wait for 60 seconds before reapplying power to the HDTV.
After you turn the TV on, if it doesn't power up, try holding the power button down for at least 8 seconds. That's supposed to force a system reset. If your model has a system reset button, use that instead. Press the reset button for about 20 seconds...release it and press it again for 20 seconds, release it again and the led will blink just for a minute or two. You should now be able to turn the TV on.
If after several attempts, the HDTV has not fully powered on and the LED on the front of the HDTV is still glowing solid red, you may want to reseat the lamp.
If reseating the lamp has not resolved the issue then your next step is to order a replacement lamp.
Apr 05, 2015 | Mitsubishi Televison & Video
TV WILL NOT TURN ON AND RED STATIS LIGHT IS ON NO CODES ARE SHOWN. WHAT DO I DO?
If reseating the lamp has not resolved the issue then your next step is to order a replacement lamp. Keep in mind that some off-brand lamps may only last a few weeks, so replacing a relatively new off-brand lamp may unfortunately be necessary.
Apr 04, 2015 | Mitsubishi Televison & Video
Dashboard symbols
Air bag fault ? what i have no idea but try cleaning the contacts under the front seats
May 19, 2013 | Cars & Trucks
50" Philips Plasma 50pfp5332D/37 won't turn on
I have a 42in vizio led with about the same problem i replaced a 75 cent chip # u33 on computer board problem fixed.
Sep 25, 2012 | Philips 50PFP5332 50" 1366 x 768 Plasma...
Protron pltv no tv signal
Unplug it for about an hour to see if it will reset itself first. This TV is known to have power supply problem, but yours has 5vdc standby working because the red light on the front is on, and the screen is also lited up blue. The problem can be the processor in the main board and will need more troubleshooting if that is the case.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Jul 11, 2010 | Protron PLTV3250 32 in. LCD Television
Tv will not turn on
You lost the standby 5vdc power supply and may be a lot of bad caps, very common problem with this model.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
Please also see my basic troubleshooting guide here:
Jun 16, 2010 | Protron PLTV3250 32 in. LCD Television
Audio but no video. was working previously???help
Are the ring lights on the front glowing green or red? 3 red lights is bad, if 4 lights try a new av cable, if all lights are green then check your tv. (Personal expriand with a similar problem).
Feb 28, 2010 | Microsoft Xbox 360 Console
We have been having problems with my Protron
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
Please post back what you find.
Dec 07, 2009 | Protron PLTV-32 Television
Protron PLTV-32 Television Logo
53 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
