Question about Pioneer PD-M403 6-Disc CD Changer
I have Reebok RL 900 and can't get any resistance, and turns off in4 to 5 seconds, from count down time.
  • John Thul Aug 04, 2010
    Everything looks real good,as new, when I follow instruction, put on manual, set ramp and resistance,all the while continuing to pedal
    push start and in 5 seconds it shuts off. The faster or slower lights never cone on.
  • 2,272 Answers
In the unit is turning on that means the power is coming to the unit.But as you said it turns off after few seconds this indicates the problem with two things.
1) The power wire of the unit is getting short or got loose or not connected properly.
2) The power supply of the board is got weak.So as you turn the unit on it turns on.But due to weak power supply board the power goes off.
So to confirm this fault,.First check the power cord wire of the unit .If the wire looks very old or crimped in between anywhere or got pulled out from the unit or burnt in between.Then that wire has to be replaced.But if the power wire confirms ok.then the unit needs to be disassembled.As its not very hard to disassemble the unit.Its just fitted on screws and internal hidden clips and locks.To detach that clips/locks you require thin and strong knife.For removing screws you require a screw driver.With this 2 tools you can disassemble the unit.Now after disassembly .In the unit you will see the circuit board that board is called power supply board.The board to which the other end of the power wire is connected.Check out on that board.There will be many tiny components seen.Any of the capacitor or ic will be weak and due to this board gets weak and cannot provide proper power.Most probably the faulty capacitor gets leaked from its top or bulged from its top or have burn mark on its side or gets blow out or gets loose from its soldering connection on board.but if this is not noticed on the components then the board needs to be checked by meter and then faulty component needs to be replaced then dry solder whole board ,so if any component which is got loose but actually its ok.Then dry solder will re tight it to the board.Then check.If you are not familiar with doing this repair then local electronics parts repair technician familiar with your units brand model is advisable to do this.It will not be too costly but it will take time to locate fault.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 29, 2010
  • 532 Answers
Hi
This problem is a factory error.
Take it back to the company and it will be rectify.
Thanks.
Posted on Aug 04, 2010
How do I find a user manual for a Reebok Space Saver RL Eliptical?
Call SportSmith and we will find it for you :) 888-713-2880 here is the link to your manual
http://www.manualslib.com/manual/508361/Reebok-Rl-725.html
If you find yourself needing any parts for your repair, if any. We would be happy to hear from you! We also do chat if you prefer, at www.sportsmith.net hope we helped out!
May 14, 2015 | Reebok RL 725 Elliptical Trainer
Reebok RL 1500 elliptical lost all resistance
I had the same exact problem, and I mean the EXACT same problem. I also changed out the battery with no change. I contacted the generator company thinking it might be that, but they told me it could be the control board. I ordered a control board, changed it out, and now it works like new.
To sum up: Get a new control board.
Jun 19, 2012 | Reebok RL1500 Elliptical
Replacement Reebok Gym Ball Plug/stopper
We have these for sale on eBay now:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=230524179989
Apr 24, 2009 | Reebok New York Giants Eli Manning Jersey
Reebok elliptical trainer belt replacement
Ask here for instructions how to change, they can get you any Reebok manual
Jan 13, 2009 | Reebok New York Giants Eli Manning Jersey
Pioneer PD-M403 6-Disc CD Changer Logo
324 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
