Question about Whirlpool Refrigerators
I'm tryin to find out how many square feet my fridge has. I typed in the model number EET202MKNR0 and it says that model doesn't exist. What can I do? It's a whirlpool type 1 fridge.
  • 4,793 Answers
Measure the inside width,depth and height,then multiply all three to give the cubic capacity....
Posted on Jul 30, 2010
How to calculate square feet
Calculate Square Footage is by measuring the length and width of your area then multiply those two numbers together, the unit of the results will be (ft2).
square-calculator-yfpx1catvhdedlle0bekpo0l-4-0.png You can use this calculator to figure out the price as well in different currencies
https://www.squarefootagearea.com/calculator/square-footage-calculator
Oct 30, 2017 | Office Equipment & Supplies
6000 cubic feet equals how many sq. feet
You can't convert cubic feet to square feet because cubic feet has an extra dimension, you could fit an unlimited number of square feet into cubic feet.
The formula for Cubic feet is:
length × width × height
The formula for Square feet is:
length × width
Aug 19, 2016 | Office Equipment & Supplies
How many square meters in 90,000 linear feet of 41.3" wide material?
First, we need to determine the number of square units in the Imperial system. We can choose to do the calculation in feet or inches.
Let's do it in inches first. There are 12" in a foot, so we multiply 90,000 by 12 to get 1,080,000 linear inches. Multiplying this by 41.3", we get 44,604,000 square inches. We can convert this to square feet by dividing the number of square feet by the square inches in a square foot. Since a square foot is one foot by one foot, or 12 inches by 12 inches, there are 144 square inches in a square foot. Dividing our previous answer by 144 will give us 309,750 square feet.
Converting to square metres. An inch is defined as 2.54 centimetres ("cm"). Thus, there are 2.54cm x 2.54cm in a square inch or 6.4516cm^2 in a square inch.
Using the 44,604,000 square inches we got above, and multiplying this by 6.4516, we get 287,767,166.4 square cm. There are 100 cm in a metre, so there are 100cm x 100cm in a square metre. So there are 10,000 square centimetres in a square metre. I get 28,776.7 square metres.
There are 3.280839895 feet in a metre. So there are 3.280839895 x 3.280839895, or 10.76391042 square feet in a square metre. Taking 309,750 square feet and dividing by the 10.76391042 we get 28,776.7 square metres.
Good luck.
Paul
Jan 08, 2016 | Office Equipment & Supplies
How to convert room measurement to square feet?
Measure the room in feet, multiply the two together.
12 feet a 8 feet room ? 12x8 = 96 square feet.
Or conversion? See below
Square Feet to Square Meters conversion
Dec 02, 2015 | Carpet Pro Vacuums
Cubic feet of my fridge and freezer model #ED5CHQXVQ00
The model number usually depicts what size fridge it is. ED 5 ?? That would suggest 5 cubic feet. ?? In Australia, fridges are measured in litre size. IE/ a fridge with say a model of HE550 would suggest 550 litres ( a reasonably big fridge)
Apr 09, 2015 | Refrigerators
My air conditioner dwc 084 rl model does not work well, can not maintain a temperature below 70
The air is cool but doesn't seem cold enough If the air doesn't seem cool enough it is necessary to use a thermometer to check the difference in temperature between the air going into the unit and the air being blown into the room. Ideally, the temperature difference should be more than 15 degrees. For example, if the temperature going into the air conditioner is 80 degrees, the temperature coming out of the unit should be at least 65 degrees or less. If the difference is 15 degrees or more there is probably no cause for concern. If the temperature difference is less than 15 degrees you should check the following:
  • Air damper
Check to make sure the air damper is closed. If it's open, it will bring in outside air and reduce the efficiency of the unit.
  • Back cover
During the winter season many people cover their air conditioners to protect the unit from the weather. In the spring or summer they will sometimes forget to remove the cover. If your unit has a cover on the outside portion of the air conditioner remove the cover first.
  • Condensing coils
The condensing coils will always be on the "warm" side of the air conditioner. That is, on the side that faces outside of the room to be cooled. Air is drawn into the back of the air conditioner on the sides through vent slots and is blown directly out through the condenser coils. If the coils get clogged with lint, dust and dirt the cooling system cannot provide the cooling necessary. To clean the coils it will be necessary to remove the entire cover of the air conditioner or pull it out of the wall to gain access to the coils. They can be cleaned by blowing compressed air at them or by using a soft bristle brush to wipe the dirt off. It is important to also clean any dirt or lint build-up in the bottom of the air conditioner so the condense water will be picked up by the condensing fan slinger properly.
It could also mean that you are trying to cool too big an area for the size of the unit.
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
Jul 22, 2011 | Daewoo Heating & Cooling
What's the conversion formula for sq. ft. to sq. meters?
The square foot is the smaller unit of area, so you will have to divide a measurement in square feet by the number of square feet per square meter. Since there are 10.76 square feet per square meter, divide by that value.
Obviously, to convert from square meters to square feet, you would multiply by that value.
1 square meter is 10.76391 square feet.
Feb 13, 2011 | Garden
4 ton HVAC Unit for 2000 SQ FT Residential Bldg (Single Story)
One ton of cooling per 500 square feet of space assuming you have good insulation. Yes, 4 tons for 2000 feet would be accurate.
Jul 21, 2009 | Ruud UBHC Air Conditioner
Refrigerators Logo
115 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
