Question about Estate TAWB600JQ Top Load Washer
How do u remove the safety which is under the lid of the washer
    Top Expert:
  • Estate Master
  • 81,294 Answers
The washer lid is held in place with spring clips, use a putty knife to pry the lid up gently and expose the switch
Posted on Jul 29, 2010
Does not spin
Could be a bad lid switch or deive coupling. This video will help.
Aug 01, 2011 | Whirlpool LSR5132PQ Top Load Washer
@aol.comhave to slam the lid hard to get it to start to wash
its the lid safety switch,its located under the control panel and you need to remove the panel,then the 2 brass colored clips then remove outer unit cover and replace the switch
May 28, 2011 | Whirlpool LSR5132PQ Top Load Washer
My washer does not spin dry but it pump out the water
replace the lid safety switch under the lid,by removing the front and top covers after removing and unplugging the control panel then replace the switch and reassemble the unit
Mar 04, 2011 | Maytag Admiral AAV7000A
Washer washes then does not spin out
replace the lid safety switch by removing the control panel,then unplug the switch harness under the panel then remove the 2 brass colored clips on the top and tilt machine toward you to access the switch under the top by the lid,its there to shut machine off if the lid is opened during spin cycle
Jan 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool washer sm8525492 will not spin or agitate
your lid safety switch is bad,remove the control panel,set it back,then remove 2 brass colored spring clips from top cover behind the lid,tilt entire cabinet toward you and remove,lid switch can now be replaced from under the cabinet that you removed
Dec 22, 2010 | Washing Machines
Lid safety switch how to get out to change how to
Remove screws from rear of timer console, pull console forward and hinge it up to expose brass colored clips. Remove these clips and unplug lid switch connector. The cabinet will now hinge forward and you can remove it to access the lid switch.
Sep 11, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a whirlpool washer estate, it will not spin. what can I do.
replace the lid safety switch under the lid by removing the control panel and then the top cover and unplug the old switch connector under the control panel you removed and remount the new switch on the cover and lid mounting area
Aug 01, 2010 | Whirlpool Washing Machines
Trying to replace the lid switch
Did you unplug from the wall? Safety first.
You should be able to slide the wires off the terminals. Or you may have one that has a molded pulg that has a safety retainer clip that has to be depressed to unplug it.
Same with the switch, it should have a retaining clip that must be depressed to remove it. OR it has a screw holding the assembly on.
Sep 03, 2009 | Kenmore 22422 Top Load Washer
Water is now filling, washing going round in drum but not rinsing or spinning.
Spinning and Rinsing require a safety switch to be enabled by the closing of the washers lid.
Check around your lid and washer lid opening to find the mechanism that is used to activate the safety switch mounted just under the lid opening inside your machine. Sometimes it is a plastic plunger(protrusion) on the lid that mates with and opening(hole) in the machine around the lid opening to cause this switch to close. Other times it is on the hinge side of the
lid and the protrusion is formed right into the metal of the lid itself to push a plunger on the hinge side to close this safety switch.
Most spinning problems on machines are cause by this lid safety switch. Washing machines cannot spin if the lid is not closed and this safety switch is not working to switch power to the spinning motor.
Aug 30, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
KitchenAid KAWS777E Washer will not spin
We are having the same problem. Try the lid switch. It is located just under the oval hole in the rim of the washer. There is a plactic pointer on the lid that pushes the lid switch down so the basket can spin. It is a safety thing. The plastic lid switch costs around $43 and is really not a problem to put in. Good luck!
Jun 22, 2008 | KitchenAid KAWS850LE Top Load Washer
Estate TAWB600JQ Top Load Washer Logo
Top Estate Washing Machines Experts
Marvin
Marvin
Justin Duby
Justin Duby
Jim Goldsmith
Jim Goldsmith
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
