Question about Magic Chef 24 in. DU6550 Built-in Dishwasher
Magic chef dishwasher--no water flowing into dishwasher.
  • Magic Chef Master
  • 43,501 Answers
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
DishwasherMagic chef dishwasher--no water flowing into - 2_bing.gif Trouble No Water entering Dishwasher2_bing.gif
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Posted on Jul 30, 2010
SOURCE: Where do you put the rinse agent in a magic chef dishwasher ?
there should be a place in the door.
Posted on Nov 17, 2008
  • 548 Answers
SOURCE: top rack not being cleaned?
Make sure the water tower is not blocked so it can rise to that level. Check the condition of the tower by pulling it up gently. If it sticks, don't force it.
Posted on Jan 14, 2009
  • 398 Answers
SOURCE: after drain cycle water remains in bottom of
check drain pump or solenoid
Posted on Mar 07, 2009
  • 34 Answers
SOURCE: the water does not drain still has soap in it
is the water backed up inside the dish washer
Posted on Jan 14, 2010
marka19
  • 1430 Answers
SOURCE: water not entering dishwasher. Worked fine one
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it’s not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it’s not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at http://appliancehelponline.com/dishfloatwaterinletvideo.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
Posted on Jul 21, 2010
Magic chef du4000v
You can install it on the cold water line. The dishwasher has its own heating element to heat the water.
Apr 06, 2014 | Magic Chef Dishwashers
Chef dishwasher will not pump out dirty water on base of dishwasher
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 19, 2010 | Magic Chef CDB6100 Built-in Dishwasher
Water does not go into the dish washer during the wash cyle. This is a new problem on an existing Magic chef dish washer.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 08, 2010 | Magic Chef Dishwashers
Dishwasher will run throght the cycle. But no water will flow
Sounds like you need dishwasher water inlet valve. This part is electrical and lets water flow during the wash/ rinse cycles. Unplug the appliance before attempting this repair. Part costs about $25 depending on model. This part is located under the bottom front panel and should be easy to replace even by someone with little experience. Should be two screw mount and two wires with slip on and slip off connectors. Easy!
Jan 16, 2010 | Magic Chef Dishwashers
Magic Chef DU2000 won't fill with water- no water spray at top or bottom. Sounds like the motor is running, but no water!
float stuck or bad fill valve,valve screen plugged with sand, water line kinked,remove valve and clean screen.put back on dishwasher make up a test cord and see if it will fill if so hook back up and run dishwasher
Dec 20, 2009 | Magic Chef 24 in. DU2000 Built-in...
Leaky Dishwasher
The dishwasher was installed with a defective fill valve or the valve was damaged during installation of the dishwasher.
Jun 23, 2017 | Magic Chef 24 in. DC4000 Free-standing...
Top rack not being cleaned?
Jan 14, 2009 | Magic Chef 24 in. DU6550 Built-in...
Dishwashers Logo
343 people viewed this question
Top Magic Chef Dishwashers Experts
Are you a Magic Chef Dishwasher Expert? Answer questions, earn points and help others
