Sometimes LG washer powers off during a cycle. After trying different cycles-rinse cycle or short wash cycle- or other things, it will restart and continue through cycle. Sometimes it will go through complete cycle without stopping. it is front loading. model WM1812CW. I have cleaned soap tray and the screens for the hot and cold water.
  • bdeem_45 Jul 29, 2010
    since washer sometimes goes through complete cycle without stopping, do not think it is damage board.
    thanks would like to know how to replace the circut board and how much it cost?
  • 10,319 Answers
It seems a relay is sticking which is on the circuit board. Replacing the relay mean replacing the complete circuit board
Posted on Jul 29, 2010
  • 6,784 Answers
HI. If this unit is completely shutting down with no lights on the panel during the wash cycle, this will be a strong indicator of main PWB failure(logic sector issues). There may be a short in the main Chip, or the entire board could be damaged.
Question:
Are you getting any error codes during these episodes?
  • Michael Masters
    Michael Masters Jul 29, 2010
    If you are not getting an error code and your unit is shutting down in the middle of a wash, this will for sure be the cause of a damaged logic sector(PWB). Its to bad that you are not willing to go through the testing stages to prove otherwise. I work on these for a living, so I know what I am talking about.
    Such a shame...
Hotpoint wma48 shuts down anywhere during cycle
which suggests possible the faulty door lock has been fitted with another faulty door lock. this has happened to me on two or three occasions in different situations.
May 23, 2016 | Hotpoint Washing Machines
Washer won t fill water
pipes maybe clear but is your area wher you live prone to limescaling? where the water pipe/pipes go into the machine there is a switch to shut on/off the flow of water during whatever cycle you want.this might be blocked or sticking. first try to select different cycles and see if any of those fills the machine with water. if no water comes its one of two things. that switch is faulty or communication between the switch and the front consule is at fault.
contact your supplier after trying to go thru a few different cycles.
Dec 04, 2013 | Frigidaire Washing Machines
Washer is making different noises during wash and rinse cycle
could have been the motor,you might also smell like a shellac kind of smell,when the motor overheats,also how old is it and what's the brand name and model number.you can feel the motor,if it's hot then it is cutting out for some reason.
Dec 20, 2017 | Washing Machines
For some reason my GE GBVH6260 washer cycles are getting hung up on either the wash or rinse cycle. Some days it will stay stuck in the wash cycle & some days it will stay stuck in the rinse cycle for...
Most likely its your water inlet valve..(cold side is not letting water in). Very common problem that usually manifests during rinse cycle since rinse uses always cold water.
According to your model # , part # is WH13X10023
Jul 10, 2017 | Washing Machines
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer stops during rinse cycle and isn't easily restartable....
Sounds like the contacts in the timer has a problem. Unplug washer. Remove the back of the washer and spray WD40 in the timer. Put towels around and under to to collect excess runoff.
Rrotate washer dial 25 times and spray some more wd40. Rotate 25 times again. Do a wash load. If it works put everting back together.
May 04, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
