Question about Andis Improved Master Hair Trimmer
How do you get the noise out of an Andis Master after using the adjustment screw on the outside.
You have to adjust the screw on the side of the clipper with the regular flat screwdriver, just turn clockwise until the clipper gets quiet
Posted on Aug 11, 2010
Hi; i just bought a andis improved master clipper and the blades stop working right after i tried to adjust the voltage ,i can hear the motor running, but the blades don't move, please help me! thanks!
I just had this same problem. My andis Masters where working and they started making a loud sound and the blades stopped working. The Problem was there wasn't enough power. I used a screw driver and turn the power adjusting screw to the Right with a flat head screw driver.the sound got louder but after I keep turn it the blades started moving again and the blades got quiet again. Tada a Quick Fix.
Dec 26, 2010 | Andis Improved Master Hair Trimmer
My friend has an Andis master adjustable and the little bracket that holds the two piece head will not vibrate back and forth like it shoud (seems to be stuck) Thanks Ed
I just put the tow piece head back on,oiled it good and turned the adjustment screw on the right side of the clipper to the right until it quit making noise and the clipper head started to work just fine. oiling is important. Ed
Feb 16, 2010 | Andis 01690 Hair Trimmer
Andis trimmers are making loud noise when used outside US
First off all when buying a step down transformer for these clippers or any other electrical equitment make sure u read the label check cycle 50/60 ,and watt transformer need to be the same are close enough,with is hard to get on tha market,get it made custom,I'm a barber and we have a little trick open your andis clipper ,get spong cut it neatly just a bit thicker than the space between movin part and amateur (coil) insert spong between,not centre bit top bit to blade that's where knocking comin from it can cause that movin bit to break,trim spong until u get it quit but able to cut ,note blade will get hot because of wrong transformer and can damage coil
Nov 01, 2009 | Andis Styliner SLII Hair Trimmer
Misses hair when cutting
You probably need a new blade drive, which is easily replaced yourself, if you are so inclined.
Apr 20, 2009 | Andis 01690 Hair Trimmer
My master andis are too loud
Turn the clipper on and with a screwdriver turn the screw on the side counter clockwise until it is extremely loud. Next slowly turn the screw the opposite direction until the noise quiets down to a low buzz. If this does not work for you there may be an internal adjustment that is necessary. If you need any further assistance please call the Andis customer service department at 1-800-558-9441.
Thank you for choosing Andis.
Sep 13, 2008 | Andis 01690 Hair Trimmer
HOW DO FIX MY MASTER ANDIS THEY ARE LOUD
Turn the clipper on and with a screwdriver turn the screw on the side all the way clockwise. Next slowly turn the screw back the opposite direction until the clippers are running at a normal sound level. If this does not work you will need to send the unit in for an internal adjustment. Please call the Andis customer service department at 1-800-558-9441 for further instruction.
Loud andis master clipper
adjust power screw in one quarter turn
Apr 23, 2008 | Andis 01690 Hair Trimmer
Andis Improved Master Hair Trimmer Logo
474 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
