Question about Linksys Wireless-G WRT54G Router
Unable to connect my samsung tv to internet using lynksys router
When i test my network connection on my tv it reads four different things cant remember them good but i remember it says ip address, mask net, something else and domain,, the first three get a checkmark but when it gets to the domain it gets an x and im unable to connect i called samsung and they troubleshoot my problem and said they are sure its my routers domain firewall not letting me connect so call lynksys for help FYI when i connect it directly from my modem i get a good connection but i need the router to work HELP! thanx
  • 48 Answers
Pretty sure you need to just open ports. You can do that @ Port forward.com
Posted on Jul 29, 2010
How to connect older tv to internet
Not all TV can connect to Internet ,
Read the documentations on the specific model of your TV
Some of the requirements :
• It needs to have a network interface.
Some model such as Samsung Series 6 and higher have
the capabilities.
• Insure that your TV can play videos and pictures
with different formats such as mpeg, flv, mp3
• These TV should be in your home network configured
properly.
To test , One computer will act as a server for files
that have sharing capabilities. Meaning you can view
from the TV, what is being shared on your computer.
• But you can extend , or use the TV as a second monitor
using your Video card, while watching movies on internet.
Jul 27, 2012 | Panasonic CT-27SL14J
I have a samsung tv , and im setting up my INTERNET@TV , it ticks off everything but the Gateway Ping ! Please Help
If the Gateway Ping test fails, then your TV is not communicating properly with your Router or Modem.
To resolve this, follow these steps:
  1. Power off your TV, Modem, and Router.
  2. Unplug the power for your Modem and Router.
  3. Make sure the ethernet cable is securely connected to both your TV and your Router or Modem.
  4. Plug in your Modem and turn it on.
  5. Plug in your Router and turn it on.
  6. Make sure your IP Address information entered into the TV during the Network Setup matches the information from your Router or Modem.
  • If you are using an Automatic Setup (most users), skip this step.
  • If you are using a Manual Setup (advanced users), contact your network administrator to determine what the correct IP Address information is.
7. Run the Network Test again.
  • If the Gateway Ping test passes, but another test fails, click here to go back to the list of Network Tests.
  • If all tests pass, the TV is successfully connected to your network.
  • If the Gateway Ping test fails again, see below....
If the Gateway Ping test fails again, there may be a problem with your network setup. To determine if there is a problem with your network, follow these steps:
  3. Connect your ethernet cable directly to the TV and Modem.
  5. Power on the TV and run the Network Tests again.
  • If all tests pass successfully, then there is a problem with your Router setup. Contact your network administrator or router manufacturer for information on setting up your network.
  • If all tests do not pass successfully, there may be a problem with the TV. Connect another device (such as a Computer) directly to the modem.
  • If the other device connects to the internet, then the TV will require service. Click the Create online service request button below to have the TV repaired.
  • If the other device does not connect to the internet when directly connected to the modem, then there may be a problem with your modem. Contact your Internet Service Provider for help on troubleshooting your modem.
(from Samsung support)
Hope this helps. -Sa_Les_Ski
Feb 28, 2011 | Televison & Video
Everything works well on my wireless linksys e2000 router my itouch, my computer except my samsung wireless lan adapter wis09abgn cant seem to connect to the internet on my Tv i plugged it in the usb slot...
IT looks like it might not be accepting the type of security on the router..try changing the security typa it might work.
(P.S. YOu might need to re-connect all the wireless computers to the new network once you change the security.)
Hope this helped.
Feb 13, 2011 | Computers & Internet
"Service not supported" with Internet@TV.
Problem persists : ------------ ----------- ---I have configured the network in the samsung 40" LCD TV, using Ethernet cable to a router. The ping test, DNS server, GW Tests are passing ok. I am able to ping to the IP address of the samsung TV from my Laptop. My internet browsing via the service provider Airtel is otherwise working excellent with Laptop (Vista) or MacBook.
Router : 192.168.0.1 Laptop : 192.168.0.16 Samsung : 192.168.0.5 GW : 192.168.0.1
But Internet #TV gives "Service Not supported"
Any known issues?
Thanks, Ilango
Sep 17, 2009 | Samsung LN40A550 LCD TV
How do you connect to the internet ?
what u can try is that install the lynksis cd on the computer and then open the network connection and then right click on the wireless network connection and then click on the view available network and then connect to ur network connection and it should work or else the best way u can do is that u can call up dell technical support and they will be definately able to help u to connect to internet cause i really cannot explain all the details here cause it need to be done troubleshooting on ur computer practically by connecting the router with the laptop with the ethernet cable and when u connect the internet with the ethernet cable then the dell guys can take the remote session in ur computer so that they can help u to connect to internet wirelessly.
follow 4 steps to connect to lynksis:-
In order to follow thesen four steps all u need to do is that just follow this link very caarefully and u will definate;y be able to connect to internet wirelessly with the lynksis..
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx#step1
Jan 27, 2009 | Dell Inspiron 1501 Notebook
Where does the phone line go in the lynksys box.
Phone Line?
You need a cable or dsl modem to connect to the internet. From the modem you run an ethernet cable to the "broadband" or "Internet" port of your router.
Also make sure your lynksys is a router, not a switch
Hope this helps
Cor
Dec 31, 2008 | Linksys EtherFast 10/100 16-Port Workgroup...
Trouble with Linksys Wireless Router
Try unplugging both the modem and the router. count to 15 then plug back in and try.
Keep in mind also that some routers dont connect 100% till you open a browser, weird but I have had similar problems.
It sounds like you may have problems at both ends.
Several things come to my mind;
make sure you shut down ALL programs in the background.
you are trying to problem solve by elimination, so close anything that may connect to the internet and take away that variable.
scan for spyware etc.
do a registry clean, temp files cleanup etc.
sometimes restarting the pc can help
good luck
haydenshaw3
Dec 28, 2008 | D-Link Wireless
Connecting wireless router to laptop computer
Try changing the channel on the router. It would be better to isolate the problem first by trying to connect to other wireless networks on your laptop or having someone's laptop connect to your home wireless network.
Sep 03, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Unable to connect via LAN with wireless router NETGEAR WPN824
I recently experienced this on laptop and desktop, using a lynksys wireless. I was able to go into each system to network connections, and tell it to connect. I haven't had a problem since........hope this helps you!
Dec 24, 2007 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
1,107 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
