Question about Ford 8n,9n,2n, Tractor Starter With Drive
Starter spins but does not seem to engage to fly wheel
    President:
  • 1,627 Answers
Odds are that you have a broken spring in the bendix part of the starter drive,which is replaceable but at the same time is hard to find separate from the whole assembly.The whole assembly will run you about 55 to 90 dollars depending on where you find it.
Posted on Jul 30, 2010
2 Suggested Answers
SOURCE: john deere 425 lawn tractor. it wont start but it
My John Deere did the same thing. Turned out to be the emergency brake sensor.
Posted on Jan 21, 2010
Behind starter fly wheel only moves back not forward wil not start not start starter seems like its working spins
Disconnect the battery and then carefully remove the starter. Take the unit to a local auto parts dealer for a bench test. Starters have two separate functions, one spins the shaft to crank the engine, the other is called a bendix, which pushes the starter gear out to engage the flywheel, and then after the engine engages, retracts it (except in the case of starter/generator combo units which recharge your battery and power your vehicle's electricals while the engine is running) Always best to get a bench test rather than depending on apparent symptoms.
May 03, 2015 | Polaris 2009 Sportsman 850 EFI XP With EPS
Starter spins on 1100 v-star Yamaha 2005
not engaging all the way (weak) , probably need to replace ,
Sep 17, 2014 | Motorcycles
My starter spins but but doesn't engage the fly wheel. Solenoid or starter?
starter, take out and try across battery and it should whirr and jump out as if connecting with flywheel, if no spray the whole starter with WD40 inside and leave overnight. worked for me.
Apr 27, 2012 | Cars & Trucks
Chrysler sebring 2.5L V6...sounds like starter is spinning but solenoid is not engaging...timing belt intact... this does not seem possible..am I crazy?
Well your not crazy but you are talking about 2 different things. The starter will spin but there is a thing called a ben-dex that is driven out of the starter motor by centrifugal force it then engages the starter ring on the flywheel, it is probably this that is stuck or seized up and not engaging the fly wheel. Answer is to remove the starter and see if this is the problem.
Nov 12, 2010 | Chrysler Sebring Cars & Trucks
When I turn the key the starter won't engage . but the starter is good and the battery is good .
Check your starter relay if you are positive both battery and starter are good. Best of luck
Oct 18, 2010 | 1999 Oldsmobile 88
Car starts but sometimes makes a whirling noise. I was told it was the starter
sounds like the starter is not disengaging the fly wheel quickly like it should when you turn the key the starter cog connects upto a fly wheel that has teeth all around it when the teeth of starter cog connect between teen on wheel it spins it to crank your car then goes back to starter if you hold your key on after starting the noise you hear is the starter cog(teeth ) still engaged in wheel if this is the sound it needs to be serviced not neccassarily replaced
Jun 06, 2009 | 2003 Chevrolet Impala
Won't start, starter will spin but will not engage fly wheel to crank up engine
Sounds like the starter drive is shot, best thing to do is replace starter with new or rebuild.
Jun 03, 2009 | 2001 Ford Explorer Sport
Ford F150 starter does not engage, spins the catches off and on
Most Likely The Starter I Know We Changed It Is What your Thinking.
I Done 3 In A Row And The Fourth One Was Finally Good.
Jan 21, 2009 | 2004 Ford F150
Ford 8n,9n,2n,  Tractor Starter With Drive Logo
878 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
