Question about Kitchen Appliances - Others
Problem with my electric jug kettle
Bought a cheap jug kettle from Argos about a month ago, I find now that when I go to empty what is left and refill, there is a brown sediment, like sand in the bottom (instead of the limescale I was expecting). I wonder if this is the coating coming off the element, and also if it is safe to keep using, there is a filter in the spout.
    Genius:
  • 1,689 Answers
The element may be rusting! Normaly rust is safe, but annoying. you should find out the type of metals to know if it is actualy safe.
Personaly, I would go and get a good quality product from a well known manufacture. This way it will be safe and dependable.
Jerry G.
Posted on Apr 29, 2008
18 months ago i bought an murphy electric kettle. today the light came on but the kettle did not boil. how long should i ex
Hi Colin, These days some folk would say you were lucky to get 18 months! Cut your losses and buy a cheap and cheerful one!
Jul 11, 2015 | Kitchen Appliances - Others
Ibought a jug kettle a while ago for a spare i boiled it out twice but we get an awful taste out of it can you give any ideas how to get rid of it please
Try washing it out with hot water with soda in it
I had something similar with the fridge and washed the smell away doing this
Aug 17, 2014 | Kitchen Appliances - Others
How do i clean my glass kettle from lime scale
try vinegar neat white or brown its less corrosive than the branded descalers which do work quicker i admit but my kettle started to leak
because of these strong cleaners now i use vinegar its cheap.
place 500 ml to 1 litre in kettle switch on just warm vinegar and switch off leave in for 30 minutes swilling round empty and you can keep in a bottle and repeat every month if you wish or use in cleaning solution if you don't want to waste it look on internet 1,000 ways to use vinegar.
wash kettle with copious amounts of water inside and then use kettle cleaned and sparkling
Aug 06, 2014 | Kitchen Appliances - Others
Bulb in Ikon kettle no longer lights up
I had this problem recently; I think my kettle have accidentally been turned on empty. The kettle has a safety for that, described as follows in the manual:
"The kettle is fitted with a safety device, which protects against overheating should the appliance be operated with insufficient water. If this occurs the kettle will stop heating. Switch 'Off' at the power
point and allow kettle to cool before refilling. The safety device will automatically reset when the kettle has cooled down."
Then they go on to tell you that there is an additional thermal cut-out, and if that is tripped, you have to send it back to Breville for servicing. However, it might not be that bad-- it wasn't in my case.
The heating connector and control is made by Otter, here's information that I was able to find about it on their website (Otter A1 and CS7 control and connector-- I think the kettle actually uses a CS4 connector, but the thermal cut out isn't described on that data sheet):
"The A1 control integrates to 360° cordless plug with element
dry boil protection. Two bimetals spring loaded against the
element surface make a fast response during dry boil. One
bimetal disconnects the live side of the electric circuit and the
other disconnects the neutral. A latch out function prevents
dry boil cycling. This automatically resets when the kettle or
jug is lifted from the cordless base."
http://www.ottercontrols.co.uk/support-downloads/domestic-data-sheets
So what does this mean to you? If you look at the bottom of the kettle jug, there is a circular indentation that slots into the base. There are two white plastic things which I believe are part of the "latch out" described above in Otter's documentation. If you see them sticking out, they may be stuck in position instead of resetting as they should. Use something like a pencil eraser to gently poke them so they unstick, then put the jug back on the base. That should cause them to retract, and at that point your kettle should work again.
Nov 07, 2013 | Breville SK500XL Stainless Steel Cordless...
Hi, I have a Bosch Private Collection Kettle. It is over a year old and has until recently been working fine. However, lately I do not feel that it boils to a high enough temperature for a long enough...
Some types of kettles use a separate power base to heat up the kettle jug. If this is the case with yours, turn the jug upside down and look. Also look at the parts on the base that touch the kettle jug contacts. If you can see the electrical contacts; mine were built on spiral rings for differing temperatures; try cleaning them with Brasso and a Q-tip (cotton swab) wiping the contacts several times to remove any tarnish and then use clean swabs to remove all traces of Brasso metal cleaner. Fill the kettle jug up to the maximum fill line and put the boiler on the maximum setting... boiling water. If the water doesn't boil... you have a more serious problem. Buy a new boiler as it isn't worth having someone fix it. Mine worked like new after I cleaned the contacts. Never immerse the jug contacts in water!!!
Nov 25, 2012 | Bosch Private Collection Jug Kettle steel...
Leaking jug
A common cause is the calcium, or some other minerals in the water eventually ate through the bottom of the tank. You will need a new tank, or better... A new kettle.
Jerry G.
May 07, 2012 | Russell Hobbs RHOK3123 Cordless Electric...
I bought a Bellini electric cordless kettle about three months ago from Target and now the lid won't shut, hence the kettle won't stop from boiling. What do I do - is there any guarantee?
i brought a belline kettle from target 2 months ago and now the lid wont shut where would i find a contact no for the company as target wont issue me a new one and i dont have my reciept after all who would have thought it would be faulty after 2 months
Aug 09, 2010 | Microwave Ovens
Dualit glacier blue kettle spare lid
Our kettle has just broken so if you'd like our lid? - if so I'll pop it on ebay?!
Apr 04, 2010 | Dualit 72102 / 72100 Cordless Electric...
I have a kettle which has now broke. Have reciept
Contact Swan using the details on the warranty card.
Jul 20, 2009 | Kalorik Jug Kettle Cordless Electric...
Kitchen Appliances - Others Logo
753 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
