Question about Samsung Televison & Video
I cannot connect my 6500 to my wireless internet. I have A T & T with a 2wire gateway router. I can get to the LAN but not to the internet AT & T uses a dynamic IP. Is that the problem ? Help Ted San Francisco
  • 903 Answers
SOURCE: Internet connection at my e830
To configure the Wireless connection you can use the Wifi connection wizard or setup the connection manually. I hope that you have checked your workgroup too. Also you should check if your IP settings are the same at the router and PDA (dynamic and static IP)! If you have some another device connected to the router remember them when you setup the PDA connection! In the end the MAC address of the PDA WLAN card must be saved in the router!
Posted on Sep 08, 2005
  • 147 Answers
SOURCE: problems with netgear wireless router
picolas and nannysboy,
You can setup your router any way you like after accessing it. You don't need software for NetGear. All you have to do to access the control panel is:
  1. Open your browser.
  2. Type in this ip address - http://192.168.1.1
  3. Configure the router as you see fit. It's fairly simple and has built in help guides.
If you cannot connect by wireless, do the above while connected by a LAN cable (looks like a telephone cable, only fatter and wider).
The router should be connected as follows:
  1. WAN port directly to cable/dsl modem.
  2. Any port (1-4) running out to your computer.
Please let me know if this helps. Good luck!
Posted on Mar 01, 2008
ronaldsuboc
  • 449 Answers
SOURCE: I cannot connect to the Wireless router Gateway if i type the Ip address of the router gateway.
hi!!!!
try to reset the router!!
what router did you used!!!
Posted on Oct 30, 2008
kakee
  • 1269 Answers
SOURCE: Connecting PSP to wifi
Change the primary DNS of your PSP to 4.2.2.1 and secondary dns to 4.2.2.2
Posted on Apr 25, 2009
Geekman
  • 32281 Answers
SOURCE: Belkin router is unable to connect to 2Wire ADSL
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
modem.
Posted on Oct 18, 2009
Http://192.168.1.254/ has been put into my home page browser but nothing happens
IP ADDRESS 192.168.1.254 is the default gateway of an AT&T modem router (RESIDENTIAL GATEWAY) (2WIRE). for this ip address should be able to view the main screen of your 2wire modem and if not your computer is connected to a different network.
1) try connecting the computer to the 2wire RG using a ETHERNET cable (if your connected via wireless)
2) make sure that the DSL light is solid and not blinking.
3) if your computer already connected by a ETHERNET cable, try accessing the same ip address if your able to view the main screen of your 2wire modem it means that your computer will be able to connect to the internet.
4) try this also:
this for internet explorer:
click tools - connections - LAN settings
( if there's a tick mark on PROXY SERVER remove it )
if you do have tick mark on PROXY SERVER then your computer have a virus, because virus can put a tick on PROXY SERVER without you noticing it.
after removing the tick you will be able to connect to the internet again.
Apr 10, 2011 | Computers & Internet
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
modem.
Oct 17, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Trying to connect my ps3 to the internet but need wireless route
That won't work because your old sbc wireless router 2wire gateway is also a modem. You need a plain router for Time Warner. Try Linksys router.
Sep 08, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
Laptop not connectiong to wireless network
Connect the Laptop to the router with ethernet cable
Verify the wireless LAN
  • Open a browser and type http://gateway.2wire.net; the Home page opens.
  • Click the Home Network tab.
  • Verify the wireless status located on the right panel (Status at a Glance) is Disabled.
  • When the status is disabled, then enable the wireless LAN .
May 27, 2009 | 2wire 2700HG-B Router (2700HGB)
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Connecting 2wire modem./router to extra linksys router
to get this right you must make sure that the 2wire will be configured to be your gateway which means that the 2wire itself will be connected to the internet then set the linksys to DHCP mode because if you dont it will give you a router behind router error , make sure that the 2wire is properly authenticated and connected to the internet to make sure access the gui by typing gateway.2wire.net on your browser and run system set up wizard
Dec 11, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Just bought a 2Wire Gateway, router/modem.
Try contacting your internet provider for set up instructions.its probably a configuration problem.RICHARDM69
Dec 01, 2008 | 2wire (1000-400108-001) Router
Wireless router
What is the make and model of your router?
What type of internet access do you have (DSL or cable)?
Are you connecting the computer with a cable or via wireless?
If you have verified that the cable connections are correct then I would try to power cycle next.
1. Unplug the modem, router and turn off the computer.
2. Plug the modem in and wait 5 minutes.
3. Plug the router back in.
4. Turn the computer back on.
Let me know the details for the above questions if we need to go further.
Dec 27, 2007 | 2wire Wireless-G 802.11g ADSL Gateway
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
