Question about HP DesignJet 120nr InkJet Printer
Hp 120nr just stopped printing! yellow light flashing
Hp 120nr just stopped printing! Printed four sheets in a row no problem.Sent next page to printer and then yellow light starting flashing and 4 out of six print color catridges showing empty. [No i'm not our ink] Tried turning off, unplugging, remove and insert all cartridges, removed paper (roll) to prompt re-align and now will not re-feed paper either. Help!
jackboy
  • 2985 Answers
SOURCE: align roll feed paper
http://www.fixya.com/support/p378733-hp_designjet_430_inkjet_printer http://www.fixya.com/support/p378733-hp_designjet_430_inkjet_printer/solutions Check also the HP web site tech help.
Posted on May 17, 2007
jackboy
  • 2985 Answers
This suggests debris in one of the feed tracks- get a vacuum to it and give it a good suckout Also take a look at www.fixyourownprinter.com
Posted on May 19, 2007
tom19511
  • 1601 Answers
SOURCE: Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
    1. Turn on the HP PSC 1200 or 1300 series product.
    2. Disconnect the USB cable from the all-in-one.
    3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
      1. Press and hold Cancel .
      2. While holding Cancel , press On .
      3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
      4. Press Cancel again.
      5. Press Copies .
      6. Press Paper Type .
      7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
    4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
    5. Reconnect the USB cable.
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Posted on Nov 12, 2007
fwadley
  • 482 Answers
SOURCE: Epson photo stylus R1800 printing anomaly
can you reinstall the software?
Posted on Nov 26, 2007
hashchathy
  • 246 Answers
SOURCE: hp psc 1350 -check cartridge
Power off switch for a 5 minute .
It doesn't work try to reinstall the printer driver
Or check whether the printer cartridge is fit well in the printer
Posted on Jul 29, 2008
HP PCS1402 keeps printing test sheet on start up
Have u recently changed ur ink cartridge ? If so the printer is printing an alignment page . Turn it off then on , so it prints the alignment page. load the alignment page on the scanner glass and press the "Scan" button to complete the alignment. Once the alignment has completed the alignment page will not be printed again until you change the next cartridge. See your user manual for details.
May 17, 2012 | HP PSC 2355 All-In-One InkJet Printer
THE FIRST TWO LINES OF A PRINTED DOCUMENT ARE PRINTING DOUBLE.
If your printouts contain misaligned vertical lines, you may need to align the print head. Make sure the EPSON Stylus CX3200 is turned on and not printing, and the Error light is off. Load plain, letter-size paper in the sheet feeder. Press a Menu button until you see Head Alignment, then press the Color Copy button to print an alignment page. On the test page, select the pattern with the two vertical lines most precisely printed on top of each other. You may need to use a magnifying glass or loupe. maint.6.7.1.jpg Select one pattern each for rows 1, 2, and 3. (In this example, pattern 8 is the best in each row.) Press the + or - button to select the number of the best pattern for the first row, then press the Color Copy button. Repeat this step for the second and third rows. Note: If you select a pattern other than 8 in any row, that pattern becomes pattern #8 the next time you align the print head. When you’re finished, press the Stop button.
Feb 10, 2010 | Epson Stylus CX3200 All-In-One InkJet...
I printed out more than i wanted to, a page is stuck half printed
You will need to remove the jammed page. If you can see it coming out of the printer, gentley pull it out. If not you will need to open the service cover, see you your manual, and remove it that way.
Please take a moment to rate my solution.
Thanks.
Simon.
Rytech Computer Services Limited
Nov 29, 2009 | Brother HL 2140 Laser Printer
HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
Feb 26, 2009 | HP LaserJet 4 plus Printer
Printing problem
Turn off printer
Hold down green button
Power on printer. (cold reset)
In printer properties choose print directly to printer, then choose print test page.
Weird problem
Feb 06, 2009 | HP LaserJet 1320 Printer
Ink Cartridge Alignment
On alignment sheet, do you see a line of yellow blocks?
And on next line do you see alternate block and yellow blocks?
(Without these, alignment fails)
If not, change the colour cartridge, re-print the page and repeat alignment.
Good luck...
May 26, 2008 | HP PSC 2110 All-In-One InkJet Printer
Printing black squares in word.doc
It sounds like this is an HP driver issue. HP drivers have built-in "optimizations" (that unfortunately have bugs) for things like printing photos. Different programs (word, for example) try to take advantage of these optimizations in different ways. When they work, they give superior photo printing (faster, with more accurate color). When they don't, you get black squares. This is why "converting" it to PDF worked for you -- Word printed it through the PDF driver instead of the HP printer driver, then when you printed the PDF file, that program avoided those optimizations when it sent the images to the printer. Unfortunately, the translation caused quality loss. If your goal was to print out something like a "proof-sheet" of photos, you might try the free photo organizer at www.preclick.com. It will print these for you, captions and everything, and should be able to avoid the driver issues.
Apr 11, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP DesignJet 120nr InkJet Printer Logo
77 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
