Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I got a jd 318 the battery light is coming on and the tractor wont stay running when i disconnect the battery terminals
    President:
  • 1,627 Answers
Locate the plug on the right side of the engine that comes out from under the engine cover and also the regulator that bolts to the engine top cover on the top right side,held in with a bolt that take 10 mm wrench.The problem is usually burnt wire end in the plug or the regulator it's self has to be repaired or replaced.
Posted on Jul 30, 2010
I want to know year of JD 318 mower by serial number.
Found a link for you,look's as your's was only made for three years.It says 318 tractor.1990,1991 and 1992,It's on page 6 of 12. http://www.greenpartstore.com/assets/images/bulletins/2012/model_year_to_serial_number.pdf
Jun 30, 2017 | Garden
Why does battery light stay on?
Can be a number of things from dirty connections at battery terminals, bad battery, low RPM when operating, bad alternator or rectifier. Try charging battery first and try it for a cut of two if possible. If you can test the battery voltage when running it should be 13-14 volts. Hope this helps. Brad
Aug 17, 2014 | Toro Garden
Wiring harness
look underneath did drive belt snap in two , rear has white plastic fan on top of it that should be rotating with engine running if not yep you broke a belt , don't know about wire could it be from front PTO they are electric so it will need a wire ,one possibility is that drive belt broke slapped front PTO and broke off wire , that musta been some snow your pushin ooh and a reminder never push a hydrostatic drive tractor without pump turning it will dammage it
Feb 08, 2014 | John Deere Starter Tractor Lx188 Kawasaki...
Battery will not stay charged.
Will the battery stay charged with one terminal disconnected?
if yes the you have a wiring problem. If no get a new battery.
What is the battery voltage when mover is running?
12.6v = not charging while running
13.7v = good charging
Oct 23, 2013 | Garden
My jd 318 wont start and back fires,i replaced the shaft key did it brack agein
It sounds like it did break again. Check the key and ensure that the flywheel is installed dry onto the shaft and the bolt in the end of the shaft is tight enough.
Gary
Sep 16, 2011 | Garden
How to get JD 318 out of neutral
Your tractor has a hydrostatic transmission, I'm not sure about the lock on the dash board down next to the key, but most hydro's, you just slam them into gear and go, and it will go back and forth till you get tired of going back and forth. I love the thing. Check it out. Hope this helps.
May 06, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have trouble starting my 316 JD tractor. When I
I do not have answer I will like to have an answer for my 316 JD no power no lights on dash battery new and was running shot off and wont stared again.Thank You
Aug 15, 2009 | John Deere New Tractor Starter w/ 317...
Drain the battery
Disconnect the negative battery terminal, using a 12v test light put one end on the battery terminal put the other end on the cable if you have a draw the light will light up, go threw and disconect one fuse at a time until the light goes out, notice the fuse you pull out when the light goes out that the circuit that you have your short or draw in good luck
Mar 20, 2009 | 1996 BMW 318
My battery wont hold a charge...its a month old, and its a cold crank, my alternator is fine as well as my starter
well if its only a month old take it back where you bought it and get a new one. its got to have a waranty.being that new they will just exchange it.
Jan 21, 2009 | 1999 Chevrolet Tahoe
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
501 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
