Question about Lexmark X2470 All-In-One InkJet Printer
Printer Lexmark x2470 doesnt recognize the cartridge anymore.
  • 906 Answers
Good day Sir, I suggest use the Solution Center. to open click start - programs or all programs - Lexmark Solution Center. find the maintenance tab. Maintenance tab help you install print cartridge and troubleshoot other ink problems.
have a nice day.
Posted on Jul 30, 2010
Replace ink cartridge
Perhaps the Lexmark X2470 User's Guide will be able to help you. Click on this link to download http://bit.ly/aeFv76. Scroll to page 42 for the instructions on how to install/replace the ink cartridge.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridge. Close the cover. Plug the printer back to power source. Thanks.
Oct 08, 2010 | Lexmark X2470 All-In-One InkJet Printer
I have a lexmark x2470 printer.i would like to know whether it as one cartidge or two cartridges.please let me know if it is available in indaia
HI,
Please note that the #2 cartridge is the starter cartridge and the after market cartridge is the #1 cartridge.
The Lexmark X2470 printer uses the #1 cartridge which prints both color and black accordingly. While printing black it uses processed black. Hence, to print color images in "Black Only," please follow the steps given below:
1. Click on "Start," "All Programs," "Lexmark X2470 printer" group and then "Lexmark Photo Editor."
2. Click on "File" and then "Open" to select the color image file.
3. Click on "Image," "Mode" and then select "Grayscale."
4. Click on "Print."
This will print the image in gray.
Sep 15, 2010 | Lexmark X2470 All-In-One InkJet Printer
LEXMARK X2470 wont print in yellow with new cartridge,
try to clean the base of cartridge and clean surface of cartrage and the base where it fits in to clean it too.
Jul 23, 2010 | Lexmark X2470 All-In-One InkJet Printer
How to get to cartridge to change it I can't figure how to lift top to get cartridge
Perhaps this User Guide(for Lexmark X2450, X2470 and X2480) link to the Lexmark website will help. Just clink on this link: http://www.lexmark.com/publications/pdfs/2007/2400/ug_en.pdf. Scroll to Maintaining the Printer, Page 42, for changing/installing cartridges. In some cases, even when the printer is on and you lifted the scanner unit cover, somehow the cartridge carrier won't go to the center for loading position. Just unplug the printer from the power source. With the scanner unit open, hold the solid white strip in the middle inside the printer. Other end of it is connected to the cartridge carrier. Slowly drag the carrier to the center for loading position. Change the cartridges. Close the cover. Plug printer back to power source. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 05, 2010 | Lexmark X2470 All-In-One InkJet Printer
Hi, replaced ink cartridge on Lexmark X2470. Now it goes as far as the "print alignment page" and freezes. Will not print the alignment page or any other page for that matter. Thanks.
Hello. The ink cartridge may not be seated properly in the carrier. Remove the cartridges from the printer. Close the cover. Clean the nozzles using a damp paper towel. Unplug the printer from the power source. Plug it back in after 10-15 seconds. When the printer asks for the cartridges, reinsert the cartridges. Also, make sure you're using the compatible ink cartridges for the printer. Let it print the alignment page all the way without cancelling it to align the cartridges properly. Hope this helps.
Mar 22, 2010 | Lexmark X2470 All-In-One InkJet Printer
"unsupported cartridge"lexmark X2470
reinstall the cartridge. Turn of the printer leave it for 10 minutes and restart again. If you still have more problem check below link, youmight find some useful info.
http://pc-and-peripheral.blogspot.com/
Oct 19, 2009 | Lexmark X2470 All-In-One InkJet Printer
How do i change the ink on my lexmark x2470
Changing a print cartridge
Removing a used print cartridge
Make sure the printer is on.
2 Lift the scanner unit.
The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
3 Press down on the lever to raise the cartridge lid.
4 Remove the used print cartridge.
Good luck
Oct 04, 2009 | Lexmark X2470 All-In-One InkJet Printer
Lexmark All-in-One Alignment Problem
-take out your cartridges and put it back in again after 5 minutes.
-print an alignment page and you have to scan the alignment page that you printed
-try to print
Apr 07, 2009 | Lexmark X2470 All-In-One InkJet Printer
Replace cartridge how
I BROKE THE BLUE CLIP THAT HOLDS THE CARTRIDGE IN PLACE CAN THIS BE FIXED OR DO I NEED TO BUY A NEW ONE? HELP PLEASE THX
Oct 13, 2008 | Lexmark X2470 All-In-One InkJet Printer
Lexmark X2470 All-In-One InkJet Printer Logo
103 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
