Porcedure to set clock on a JVC KD S25 stereo
SOURCE: cannot set clock on my JVC KD-G335
You need to hold the sel button down for a little while then it will change displays thats when you use youe right seek button until you hit the Clock H to change the clock hour or Clock M to change the minutes when you hit it you use your volume control button to change the time.
SOURCE: setting clock on jvc radio
Hey here is an instruction page for your clock.
http://resources.jvc.com/Resources/00/01/13/LVT1775-001B.pdf
SOURCE: i need to set the clock on my jvc kd-g340 car stereo
make sure radio is on and you press and hold sel (select) button
when you see demo release the select button(you might see other option if you have access the menu options). then press the forward button until you see clock h (hour). to adjust turn volume knob. then press the fast forward button again to get clock m (minute) and use volume knob again to adjust minutes. once you are done make sure to press select again to save the time.
SOURCE: Setting the clock on JVC KD-G230
Check out this pdf http://resources.jvc.com/Resources/00/00/91/GET0408-001A.pdf
SOURCE: how do you set the clock on a JVC KD-R200 car
Press and hold SEL button until the menu appears
Using the scan (FWD/REV) button, select Clock H
Using the volume knob, set the value
Using the scan (FWD/REV) button, select Clock M
Press SEL to save and return.
