Question about Hitachi 43FWX20B 43" Rear Projection Television
Line in pic
I have a 43fx20b that was dead, the fuse was poped and x901 was burned up.. after replacing x901 the set fires up but i have a faint line in the pic that is in the center of screan , it is not crt burn , it is in the video..
any ideas?
  • mday911 Mar 09, 2009
    What is the rating, or model number for X901, I have same exact problem
  • 927 Answers
Good Day, varndog;
Line on left side of pix,? It sounds like you have a high voltage leak. Check all high voltage cables and make sure that they seated firmly, all of those big red cables.
Good Day and Luck, big IRISH.
Posted on Aug 16, 2008
2007 kia rondo brake light fuse keeps burning out. replaced the brake light switch already. any idea what would cause this? its a 15 amp fuse can i replace with a 20 amp? ty
yes you can but only if you want to burn the wire harness.
fuses burn to prevent damage to the harness and setting the car on fire and the correct fix is to find the dead short after the fuse
check that you have the correct bulbs in the stop lights because if a single point contact has been used in a double contact holder that is a dead short
check for damaged wires or screws that have cut through the wires
Jun 19, 2017 | Kia Cars & Trucks
Inteior fuse keeps poping
fuses are used to prevent the wiring catching on fire and burning the vehicle when there is a short/. Remove the 25 amp fuse and find where the short is and fix it. It may be in the light it self where a wire is touching the earth.
Jan 06, 2014 | 1999 Cadillac DeVille
Portable DVD blowing fuses
Thankyou,
Hello, the fuse poping is definitely as you say, please let me give you some more insights of my idea. The fuse is poping because there is a by ~ pass, most likely before its power board, that by ~ pass also causes a shorting most likely in the cigarettes lighter wiring. That is why even if you turn it off, it still shorts, Try to see exactly what went out of place to give a better understanding of the error in the circuitry, once that has been archieved, you may kindly contact manufacturer/dealer for layout of the wiring and rectify the shorting. The shorting is delivering way too much power because of the by ~ pass that over rate the fuse rating. Or try a much higher fuse rating.
Thankyou, :)
Jun 24, 2009 | TruTech LMD-5702RT Portable DVD Player
Stop working, burned fuse
although unfamilliar with your particular induction cooktop.If you have a fuse thats gone bad, adn you replace adnthat fuse goes bad upon powering up, it sure sound s as if you have a dead short somewhere under there triggering it to blow. no wires touching any metal (fallen off terminals perhaps??))if not id start diconnecting power line leading to individual switches, perhaps a short within the switch if shorting out unit.
Apr 02, 2008 | Crock Pots & Slow Cookers
Blew the Fuse in my GE PDW9880LSS Dishwasher
There is no in-line fuse in your dishwasher. If water has gotten into the junction box, (where the dishwasher and supply line are connected) it could have shorted at that point. Call a technician for service.
Sep 27, 2007 | GE 24 in. PDW9880LSS Stainless Steel...
Orion FTDV 2004 Dead Set
Question, when I clicked on this I clicked on a problem for a Sony KV27S10 but your text say's Orion, is it a Sony or a Orion?
Aug 18, 2007 | Sony KV-27S10 27" TV
56 V - faint horizontal lines across the display
u can search problem in vertical section may be sum IC component was dry resold them .
Aug 02, 2006 | SAMTRON 55V 15" CRT Monitor
SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
Mar 25, 2006 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Hitachi 43FWX20B 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
