Question about RS1000 OLED 2Way OLED Remote Start w 6 Channel Alarm
Alarm quit auto starting and turbo timeing out for cool doun but seems like it wont program. arm and disarm work fine
    New Friend:
  • 103 Answers
You need to check the nuetral safety wire. It is black with a white stripe.
Posted on Aug 13, 2010
How to ARM and Disarm a self contained ALARM system
An alarm that only sounds for a couple or three minutes, easily defeatable by way of crowbar on plastic? come on.
Nov 30, 2014 | Cars & Trucks
What is the valet button located inside of glove compartment used for
It is used for programing the alarm, it is used to disarm the alarm without the remote, [in case remote is damaged] and it is used to put alarm system into valet mode, [service mode] valet mode is only really needed if the alarm has been programed for passive arming, [alarm arms itself].
Your main use for the valet switch, [if programed for active arming instead of passive arming] is to have a way to disarm the alarm if the remote does not work.
Apr 22, 2012 | 1997 Cadillac DeVille
Hi. I have a Viper 5701 alarm in my car. Arm and disarm goes very well with the control unit. But I cannot programming to pasive arming, always have to use de button in remote control to works. Is ther a...
Open door, turn ignition on then off. Press aand hold programming button until you hear one chirp. After you hear the chirp, release programming button, press and release button one then press and hold. You will hear one chirp. While holding the programming button, press lock button on remote to change option. One chirp is active arming(what you currently have), Two chirps is passive arming without locks, Three chirps is passive arming with locks. Turn ignition on to exit programming. Test system.
Jun 13, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My 2001 tahoe alarm keeps "auto" arming itself after about 30 seconds. How do I stop it from "auto" arming? Its driving me crazy
this alarm works with the remote and the key, if you lock with the key it arms if you lock with remote it arms,when you unlock it it should disarm, if your having a problem with it not working try the pass/side lock with key, that should shut it down but if it keeps rearming without locking doors then it may be aftermarket, also in your manualy it will show you that some factory alarms are also self arming this is programed through the cluster, using the buttons on the dash, you scroll through the options and shut off auto arming, this is done the same way you scroll for mileage or trip time or oil change life. hope this helps.
Sep 21, 2010 | 2001 Chevrolet Tahoe
I bought the car with wiper alarm system and remote start. it wont start the vehicle, could it be because of low battery, the alarm its self works fine, arm and disarm
it may need to be programmed.......
-press the "f" button and hols for 12 seconds (ignore the beep at like 4 seconds.)
-press and hold the unlock button for 2 seconds...the remote should beep two times. each feature that is active will have an led light beside it. press the button to activate the feature. if the light is on the feature is on...
hope it helps...
Jan 06, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Intermittent arm/disarm of Python model 560XV
this "could" be a bad ground, however, usually when these units lose ground, they activate the siren at a really low level, because they are trying to ground through the siren.
I would say to check where the antenna plugs into the main unit,(brain) but honestly, in 17 years of dealing with DEI alarms, 99.9% of these problems are due to the transmitter - it may blink the LED like it is supposed to, but that doesnt gaurantee it is sending a signal. I would recommend buying a new transmitter and programing it to the brain.
Jan 15, 2009 | DEI Python 1400XP Remote Start/Keyless...
Alarm
No, the factory alarm is armed and diarmed either by the power locks locking/unlocking or there will be two wires to arm/disarm the factory alarm. Depending on the specs, it may auto-arm the alarm every time the doors are all closed and locked, so you may have to get an aftermarket alarm or wire up a switch to deactivate it.
Jul 26, 2008 | 1996 Toyota RAV4
Anti theft system
I'll assume you used the remote here (like most of us do) to arm the alarm. Try turning the key in the door lock - turn it to lock the car (which arms the alarm), and then unlock it (which should disarm it). Do this a couple of times if need be, and it should disarm and allow you to start the car.
Jul 20, 2008 | 1998 Volkswagen Golf
RS1000 OLED 2Way OLED Remote Start w 6 Channel Alarm Logo
117 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
Marvin
Marvin
baire
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
