Question about Janome Memory Craft 5700
I do not know how to thread and start as I do not have a manual
  • Janome Master
  • 7,365 Answers
Check with janome they can put you in touch with a dealer or try these website
sew usa
sewing manuals.com
ebay
Posted on Jul 29, 2010
Manual for dial sew machine how to thread would be helpful to know how to set tension too
Search for:
Make Model threading
or
Make Model manual
Usually, the top tension factory setting is the midway point between high & low numbers. However, every machine differs and changes over time. But that is a good starting point.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Mar 17, 2017 | Sewing Machines
After threading the machine, start to sew and the thread breaks it seems that it gets caught in step 4 in Threading The Machine in the manual.
Not knowing the make & model of the machine limits out ability to help. What is Step 4? When threading the top thread, ALWAYS RAISE the presser foot. Verify that the thread path is correct--mis-threading is a frequent cause of broken thread.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Is My Thread Breaking How to Avoid Thread Breakage at Your Sewing...
Mar 16, 2017 | Sewing Machines
I cant feed the overlocker.. so it dont want to work
Best to refer to the owner's manual. You can search the internet for the Make + Model + the word "Manual" and you may find a free download.
ALWAYS raise the presser foot while threading the machine.
Be sure to thread each in the order specified in the manual (usually, Upper Looper, Lower Looper, then the needles). Threading in the incorrect order will guarantee failure!
If a thread breaks or the machine messes up, it's usually best to remove All the threads and rethread from the beginning.
To start out, it helps to use a combination of different color threads.
Set the tensions to the midway point (the standard for basic overlocking).
Jul 20, 2016 | Sewing Machines
Brotherps31 instruction manual
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
to find a manual, we have to know the model number of the machine
to to
Jul 14, 2014 | Brother LS-2125 Mechanical Sewing Machine
Can't figure out how to thread a Singer AK30037
There are generally markings on the machine; if you have followed those, you need to know that before stitching, you must draw the bobbin thread up to the top, and then hold both top and bottom threads loosely when you start up.
Dec 29, 2013 | Singer Sewing Machines
Find free manual for white japanese sewing machine model #1010
check this link & see if it's the manual you need
http://www.singerco.com/uploads/download/738_white-445,988,999,1010-x.pdf
The needle thread breaks
the feeder bar, do you mean the feeddogs, that are in the needle
plate?
for the feeddog part try sew4less.com
Aug 14, 2012 | White Sewing Sewing Machines
Dont know how to use the sewing machine so how do i thread
well!I If you buy a new sewing machine it has a manual to guide you in any brand.But if buy a used one sometime it doesn't have a manual, you didn't mention the type of sewing machine you want to use any how if you have a mechanical sewing machine it's better to start on it.First you must know and must familiarize the significant part of machine and important usage of them,I'll just mention the most usage part at start.Putting thread in bobbins first there is bobbins winder where thread was wind,draw thread from spool through bobbins winder tension disc located at top of machine.wind thread around an empty bobbins serveral times then,place bobins onto bobbins winder shaft with thread wound on bobbins clockwise sometimes this is located at top right side a shaft coupled to circular rubber touching handwheel perpendicular sometime it was located at right side front of machine near handwheel.Release clutch by pulling handwheelor rotating pivot wheel counterclockwise at the center of handwheel whlle holding freeze the handwheel tigh in order to disingage the motion of handwheel from mechanism of machine.
Mar 11, 2009 | Sewing Machines
Simplicity Denim Star SW 210
Thread looping / bunching under fabric sewing.
Incorrect or NO top thread tension, Incorrect threading
Re thread top thread and thread machine with presser foot lifted allows thread to locate into the correct thread tension route.
Thread has not been pulled into thread tension unit- re thread, make sure thread is kept taut while threading.
Jan 03, 2008 | Simplicity American Denim SA1100...
419s
I'm happy to say I found your manual here which includes the threading guide.
http://www.janome.com/documents/File/ManualFile/423S_Instr_book.pdf
Regards
Oct 18, 2007 | Sewing Machines
How to i thread it
You can download the manual from the link below: http://www.simplicityhomecare.com/manuals/ There is a quick start guide & full manual. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 21, 2007 | Simplicity Liberty SA1600 Mechanical...
Sewing Machines Logo
44 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
