Question about RCA Scenium M61WH185 61" HDTV
No picture rca scenium dlp model m61wh185 ser. g373c602w service m61wh185yx1 chassis atc3516. as said no picture but do have sound. Put in new lamp no change. no clicking or busing Have replaced lamp once and had internal power lead repaired at a shop a year after bulb replacement. Repairman said color wheel was also weak but still working. TV is 3yrs old. help!!!
SOURCE: RCA DLP TV needs color wheel replaced
I used the internet and found others who had the same problem. Two individuals had a brief description on how to replace the color wheel in a DLP TV. Three small torque screws and a ribbon connector was all that was need for removal; once the access panel on the back was opened. I would guess that this process is the same for all DLP TV's, with some small variations!
Posted on Nov 30, 2008
techman
  • 3130 Answers
SOURCE: how can i check my lamp ballast in a rca scenium
are you sure when you replaced the lamp you seated it correctly, no really hapens all the time so dont feel bad. also another common error is the lanp door is not seated or closed and locked properly that is the most common problem that happens after a lamp is replaced, or the new lamp is bad never throw out your old one as somr dealers will give you what they call a core refund , they reuse the case around the old lamp. some can be worth as much as 50 to 60 bucks!!!
Larry Dillon
(AKA) (TECHMAN)
Posted on Sep 04, 2009
SOURCE: no picture good sound good lamp can change channel
I have the exact same TV and have had the exact same problem. I talked to a TV repairman who said it has to be my deflection board. I just found this out today so I am looking all over the web for a deflection board. I hope this helps! Tyson
Posted on Oct 07, 2009
  • 1030 Answers
SOURCE: My RCA Scenium HDLP50W151 TV has no picture. It
do you here a whining sound when you plug it up. when these units are first plug up there is a part called the color wheel that spins during boot process. if it doesnt reach speed then the lamp never fires. It is a motor and anything that moves evientally stops moving. it would have to be replace if you can get the part
Posted on Dec 10, 2009
SOURCE: I own a RCA DLP Scenium TV 50 inch 5 years old. It
mine does the same exact thing nothing fixes it, it only goes away after the tv warms up
Posted on Feb 21, 2010
M61WH185 rca scenium front panel flashes 5 times and no picture
this is the tv's way of saying that my lamp is getting weak or is about to go.
Sep 06, 2010 | RCA Scenium M61WH185 61" HDTV
RCA Model M50WH187 DLP TV - lamp cuts out
The lamp ballast supplies power for the lamp, and it is probably going out. You can probably find one on eBay or ShopJimmy for under $100. It looks like a little box and it will be near the lamp.
May 01, 2017 | RCA Scenium M50WH187 50" HDTV
50Inch RCA dlp Scenium
Its the color wheel assy. Its changing speed due to worn bearings. You may also hear a hum coming from the rear of the TV. Seek an RCA authorized service center to resolve this.
michtech
Feb 12, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Jan 15, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
The rca scenium / src / dcr /dlp /51"/ hdtv -picture doesnot appear -could heard the sound
you need to replace the bulb. It costs about a hundered dollars and you can replace it yourself. refer to the lamp replacement instructions that came with your set
Oct 20, 2008 | RCA Scenium D40W20 40" Rear Projection...
Sound but no picture
Sounds as if the lamp has gone out...accordianman
Feb 27, 2008 | RCA Scenium M61WH185 61" HDTV
Buzzing loud noise constantly.
I HAVE A RCA 50 HDTV DLP MODEL #D50LPW134 IT MAKE A BUZZING SOUND AND NO PICTURE i CHANGE THE BULB AND STILL NOT WORKING.
cantrin@hotmail.com
Ken
Dec 12, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA Scenium M61WH185 61" HDTV Logo
103 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
