My decktop holds whenever i insert any device thruogh the usb port.what do i do
    President:
  • 2,571 Answers
Try look for motherboard driver updates
Posted on Jul 29, 2010
M2n68-la beep codes
Whenever electronics devices give high pitched beep, it generall means a future failure . There could be reasons for the same.
1. Static built up on the motherboard
2. Conflict on the USB ports.
Troubleshooting 1 :
1. Diconnect all the wires from the tower, including the power cable. Press and hold the power button in the front to remove any static from the motherboard.
2. Check and try again the devices on the USB port.
Troubleshooting 2:
1. Check USB ports for damage , try connect the device to the back of the tower.
Troubleshooting 3
Clear the motherboard setting , use the link attached and see clearing the BIOS settings
Thanks for using fixya
Proton
Jul 07, 2012 | Computers & Internet
EMachines 270 rebooting whenever new USB inserted
sounds like you have a short circuit try a diffferant usb port or a usb extension
Feb 11, 2012 | eMachines Computers & Internet
I have a Sandisk Cruzer 8GB pendrive. I was copying files halfway until a message pops out telling me that my drive is not there. i ejected and reinserted the pendrive, but I couldn't delete any files...
Right click my computer and click on manage. In disk management try to reformat as another solution for your usb storage drive. Try another usb port on your computer as well when you reinsert it and restart the computer. Usually when a usb device turns off and doesn't show up like yours did the device could be faulty or the usb port you have it connected to or for laptops sometimes the usb ports turn off if only using battery instead of ac adapter. There are power save modes for usb ports so have to check that in device manager as well. Good luck!
Dec 22, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I'm having compaq presario MV540. I'm facing certain problems using it which are as follows:- 1. As sooon as i swith on my computer my dvd rom automatically comes out and goes in without giving any...
As far as the cd drive goes, get that replaced cause with the door closing and shuttin on its on, it could broken pieces of debris in there thats causing it to do that or the board inside of the cd drive is broken so either way replacing that would solve that issue.
As far as the USB ports are concerned, try hooking up other USB devices such as a USB keyboard, USB Mouse, flashdrive. Try other things to see if you get the same thing, if you do then that means the motherboard is bad cause all of those ports connect to the motherboard.
As an alternative solution to try, if you don't have anything important to save off of the hard drive, you can restore your computer back to factory defaults and then try the usb ports again and if they still dont' work then you know for sure the motherboard is bad. At that point you can replace the motherboard or find a USB card that plugs into one of the PCI slots. That would give you other usb ports to try.
May 22, 2010 | Compaq MV 540 15" CRT Monitor
One of the USB devices attached to this computer has malfunctioned, etc.
This problem is caused by a USB ports of the motherboard. Try to insert the usb devices in the different usb ports and if all ports you inserted encounter the same problem then probably the ports has technical hardware problem. To solve this, buy an expansion usb card to your computer. Be sure also that the usb devices you inserted in your computer in properly working and has no defect to determine that the ports are the problem and not the devices. Please don't forget to rate me..Thanks..:-)
Oct 26, 2009 | HP LaserJet P2015 Printer
My usb port of my Compaq Armada E500 Laptop no
the usb port of my hp Compaq Laptop nc6000 no longer works properly. whenever i insert a flash it says usb device not recognized.
Jun 03, 2009 | Compaq Armada E500 Notebook
Whenever I insert a new wireless mouse or any thumb drive into a USB port my Aspire asks for a driver. Previously the drivers for these devices installed automatically.
You probably turned it off by accident. Go to Start > Control Panel > System > Hardware and choose "Windows Update" under "Drivers". Make sure either the first or second choice is selected.
May 28, 2009 | Acer Aspire One AOA150-1784 Netbook
My pearl th1602 is froze
Remove battery, press and hold "Play" button when inserting into USB port. Run the firmware update and should be able to re-initialize the device, start the update with the "Format" option checked. Worked for me.
Feb 24, 2009 | RCA Pearl TH1102 MP3 Player
Device not detected
If you are having problems with all usb devices, then you'll probably find that your usb ports aren't configured properly. This means that there probably isn't a problem with the Mobilepro.
Using windows update, (you really need this to be set to search/download all microsoft products), download all available updates using the custom search. With laptops, not all drivers/updates will be available, as they would have been modified slightly by the laptop manufacturer. So you also need to download the most current chipset drivers from your laptop manufacturer's website. This should sort the problem.
Dec 05, 2008 | Computers & Internet
Computers & Internet Logo
14 people viewed this question
Alun Cox
David Payne
David Payne
