Question about Clarke Power Products Clarke 130EN Wirefeed Welder - 110 Volts, 130 Amps, Model# WE6523
Where can I get a maual for a Clarke weld 100E MK2 wire feed welder?
4 Suggested Answers
luis_david
  • 407 Answers
SOURCE: I am having problems having the welding wire
Have you change the gun liner? Change if you haven't done it in the past year.
Posted on Dec 18, 2010
luis_david
  • 407 Answers
SOURCE: I need contact tips for a Clarke Mig welder 100E
Substitute your clark tips for Tweco ones, which are available at all welding stores. Find your nearest Praxair location in the website www.praxair.com.
Part number os TWE 11-30 or TWE 11-35 depending on the size of your wire .030 or .035.
Posted on Jun 14, 2011
luis_david
  • 407 Answers
SOURCE: I have a clarke 100E MK2 gas mig. Will I get a
Hi:
It's redundant if the wire is fluxcore, gas does not help here. BUT if you use a DUALSHIELD wire then the quality of the welds are outstanding, even if you use pure CO2 gas.
Best Dualshield wire out there is ESAB's 710X and it is not expensive.
Have a great weekend.
Posted on Sep 09, 2011
It willnot weld
if it is just not feeding wire, check the tension on feed wheel. Make sure it turns when trigger is pressed. Also make sure you have gas with solid wire. If you have cored wire gas is not needed.
Jan 16, 2012 | Clarke Power Products Clarke 130EN Mig 110...
I have a 100e clarke the wire speed board went bad feeds fast all the time where can I get 1
It is likely the SCR's failed. It is much cheaper to replace those than the entire board. Also look for bulging electrolytic capacitors as they would indicate a shorted condition as well.
Jan 11, 2012 | Clarke Power Products Welding Tools
I have a clarke 100E MK2 gas mig. Will I get a better weld by using a flux core wire in conjuntion with the gas or is this just overkill?
Hi:
Sep 09, 2011 | Clarke Power Products 5 030 Clarke Mig...
I need contact tips for a Clarke Mig welder 100E MK2
Jun 13, 2011 | Clarke Power Products 5 023 Clarke Mig...
I have a clarke weld 85 en mig welder which starts to weld without having to press the trigger on the gun. what could cause this please
I have a clarke 85en no gas welder. the gun on this particular welder is always live the trigger only feeds the wire
Mar 08, 2011 | Welding Tools
Need manual for 100E MK2
Hi:
Follow this link for clarke models pro-90, 100E and 150TE MIG,
http://www.mig-welding.co.uk/forum/files/clarke.pdf
If this help was useful, please vote.
Thank you
Feb 06, 2011 | Clarke Power Products Mig/Fluxcore Only 95...
Runs but gun dosenot opreate, it is a clarke 130en
The only things I can think of are:
  • The tension on the coil of welding wire is too tight and needs slackening off.
  • The feed rollers need cleaning and the tension adjusting.
If none of these solutions solve your problem then I can not help you any further.
Dec 04, 2008 | Clarke Power Products Clarke 130EN...
Clarke Power Products Clarke 130EN Wirefeed Welder - 110 Volts, 130 Amps, Model# WE6523 Logo
458 people viewed this question
Top Clarke Power Products Welding Tools Experts
 Kenneth
Kenneth
Wade Mobley
Wade Mobley
Are you a Clarke Power Products Welding Tool Expert? Answer questions, earn points and help others
