Question about RCA F36650 36" TV
Rca tv powers up and down automatically. - RCA F36650 36" TV
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 132 Answers
Do you mean it comes on and off by itself? If that's what you mean, then you need to replace all the tact switches(the buttons) on the set. This is a very common problem with many rca's. I've had to change them in several rca's to fix this problem. You need to change them all(power, volume + -, channel + -, menu.
Some people have luck by unsoldering them and letting them soak in rubbing alcohol for a while which will clean them. If you go this route, just make sure that you let them dry out before reinstalling. Also, while they are in the alcohol, press each one of the buttons several times. This will also help to clean them better. As long as they all look the same, it will not matter which ones are put back where.
Posted on Jul 29, 2010
I have my ps3 plugged in but powered off so just a red light is on.i push power button light turns green I hear fan come on and everything sounds normal but it has no picture at all.it takes cd no pro
Rudy, are you connecting to the TV with HDMI, or RCA cords? HDMI carries both picture and sound thru 1 cord, whereas RCA splits it to YELLOW RED and WHITE. The HDMI connection is automatically detected when connected to your TV. It will say"HDMI is detected, do you want to use these settings?" RCA is not automatic, and is prone for the video(YELLOW) cord to develope a bad connection. I wouls duggest first replacing the cord. They are inexpencive, and the fastest way to check your issue. I am going to include a link to a youtube video that will guide you through the steps on how to reset your video settings on your system.
How To Reset PS3 Video Settings PS3
Oct 08, 2014 | Sony Playstation 3 (PS3) Console
Volume automatically goes to the loudest
There should be a setting that allows you to set the "Power On" volume level. Check the menu Under Volume settings.
What is the make and model of the Television set?
Nov 22, 2012 | RCA Televison & Video
No signal from the RCA output on ps3 but works fine through hdmi cable
Ok...little trick......ready????? Hook up your rca cord to tv....Make sure hdmi cord is not plugged in. Have your ps3 where its on standby (redlight). Push and hold your power button down for about 5-7 seconds....you should hear a beep or 2. let off button....wait a few seconds and you should be in business.....The ps3 automatically detects hdmi....but if you switch back to rca you have to reset it.....Let me know if this helps
Mar 17, 2012 | Sony Video Game Consoles & Games
In a hotel with a tv that only has coaxial input. bought a rf modulator video converter from rca to coaxial. Was running hdmi at home. current set up does not work? console should automatically switch to...
Unfortunately it does not automatically switch. Turn off the power to your PS3 and then turn it back on again. But when you turn it on, hold down the power button until you see something on the screen. When you hold down the power button of the PS3 when you are turning it on, it completely resets the video settings to the most basic settings (480p I think) so that it'll work on any TV or monitor. You can then configure the video settings to match the TV you are hooking up to. You'll have to do the same thing when you take it back to your original location.
Dec 01, 2010 | Sony Playstation 3 (PS3) Console
I have a RCA HD52W59 TV. Shuts off automatically.
Power supply is my initial thoughts, but then again it could be that one of the three CRT's tubes has an issue.
My thoughts is that it would be best to bring it to a good TV repair shop.
Why spend money on a power supply and then find out it's a CRT.
Blessings,
A/V Media Guy
Nov 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Need code for rca remote control
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 25, 2009 | RCA RCR450 Remote Control
The buttons on top of mt tv go crazy the flip channels automatically and turn volume up and down automatically
I have had this problem on this same model (F32650) and I discovered that what is happening is that dust and debris are causing the microswitches in the panel to short, therefore the channel starts changing and wont stop or the volume changes etc...
Get some electronic switch cleaner and (with the power off of course!) spray into the crevaces around each button and press each button a few times and then power the unit back on and it should be fine.
May 08, 2009 | RCA F32650 32" TV
RCA F32668 model tv flicking channels on its own
Tuner Has Bad Solder Connections Internally
Nov 12, 2007 | RCA F32668 32" TV
In RCA T13208 13 in. TV/VCR Combo shut down after turn it on
The safety circuit is sensing a problem and is why it will not let the tv stay on,the cause could be a problem on the mechanics of the vcr,you need to get an estimate to see if it is worth the repair and might be able to keep using just the tv.
Sep 23, 2006 | RCA T13208 13 in. TV/VCR Combo
RCA F36650 36" TV Logo
156 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
