Question about Westinghouse LTV-37WI 37 in. LCD Television
My 37in westinghouse monitor shuts off for no reason.It seems to stop after it warms up.It does this about 5-6 times.I have to push the power button off then turn it back on.
  • 11,361 Answers
You may have cold solder joints, bad caps in the power supply, or something is shorting out in the backlight inverter board. You need to open it up and look.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Jul 30, 2010
I have a separate fax line for my Canon MX310. It goes into fax mode but noting happens. I also cannot receive faxes.
The only reason to call the phone company is if you're not getting a dial tone on that line. Otherwise, have you shut down the printer and tried to reset it to factory defaults. To do that, follow the instructions below:
  • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
  • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
  • 3 Release "Stop/Reset" while holding down the "Power" button.
  • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
  • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
  • 6 Push the "Power" button, then lift the MX310 cover open.
  • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
  • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
  • Good Luck Mark
Feb 20, 2015 | Canon PIXMA MX310 All-In-One Printer
I have a Westinghouse monitor Model # LCM-19v SL the monitor keep turning off. Unplugging then replugging gets it working then it shorts out again. Can I replace the power Supply cord - Potrans ITE Power...
i also have a 19" westinghouse monitor the screen on mine goes black i just turn the monitor of then back on the problem is it's overheating and from what i understand it's caused by faulty or worn capacitors the ones that are bad are vented on top so it's easy to tell the bad ones. you can see what they look like on line!
Nov 18, 2010 | Westinghouse LCM-19v1 Monitor
Westinghouse keeps shutting off randomly
Power supply board finally dies.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply for the replacement.
Apr 17, 2010 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Goes dark for 5 to 10 second for no apparent reason?
Look for bad caps in the power supply, it will get worst and can take out the inverter fuse and the MOSFET.
http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/
Feb 10, 2010 | Westinghouse L1975NW Monitor
Moniter just stopped working. when you power it up
johnharold3, You didn't say, but I hope it's coverd by a warranty or some kind of service plan. If westinghouse can't or won't help you out, then get back here on fixya and someone will give you some help. You are not an electronic's technician or BSEE, If you were you would not have posted the symptom listed above, but would have already troubleshooted and possibly even repaired the unit. Johnharold3 you will also need to see some youtube video clips of LCD monitor disassembly,just so you can see what is inside a typical LCD. It may also be of interest to you to find out what are the top two or three reasons why so many LCD monitors (all brands) are failing prematurely. Well, anyway, it seems that the only options you have will be to trade in and get new, OR repair your current unit. Bye for now.I'm louie12fix on fixya or lmistyrel @aol.com
Sep 25, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Westinghouse LCM-19W4
I had the same problem with my two LCM-19W4 monitors. Both failed within two months of each other. Radio Shack stocks 220uF 35V capacitors that work fine for this. You have to pay $1.49 ea though.
Nov 02, 2008 | Westinghouse LCM-19v1 Monitor
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on).
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Oct 11, 2008 | Dell XPS 200 PC Desktop
Monitor losing power
It has possibly decided to close down. Some monitors have a power shutdown as power saver of two or more levels. It may wake up from pushing a button on the monitor. Check on the screen settings to see if monitor can stopped doing this. I had a monitor that did this years ago, long since replaced.
Sep 08, 2017 | Westinghouse LCM-19v1 Monitor
Westinghouse LTV-37WI 37 in. LCD Television Logo
78 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
