Question about Refrigerators
Hi, my slush machine (taylor 345-27) is not drawing products. I couldn't understand why? I showed up everything is ok. Syrup is ok, water is ok, everything is ok, but no syrup or water come to the front two cylinders. Please help me. Thank you.
How to adjust the viscosity of slush on my taylor 390-27. the compressor never shuts off and the slush gets way to stiff.
Circuit board in control box in left side. Two red lites on same. Adjust proximity sensor in or out that's sensing rotating torque coupling drive shaft mates with when product liquid till one lite stays on all the time.
very small blue blue box on circuit board with tiny brass screw that turns to adjust product stiffness. Other lite lites when viscosity achieved.
if torque coupling, proximity sensor or circuit board have issues or brix of product off this won't fix issue.
also torque pin must be place to stop center piece in barrel from rotating to load torque coupling as product thickens
May 17, 2018 | Taylor Ice Cream Makers
Why does my ugolini slush machine over freeze only on one side?
check your mix. if it's too lean (not enough syrup base), it'll freeze too quickly. if the auger stops moving when it's freezing, you blew a gear and it won't know when to stop freezing. also if the torque spring on the right side of the motor (through the back) is broken or missing, same thing.
Jun 27, 2014 | Kitchen Appliances - Others
In slush machines, how come the slush does not get completely frozen?
slush is made from sugar and water bonding together. the sugar is used as an antifreeze and then the mixture is constantly spun by the machine in order for it not to freeze.
Jan 24, 2013 | Kitchen Appliances - Others
Why can't you use Pepsi or Coke in a Bunn Ultra 2 machine
the brix level (syrup to water ratio) may be too low, which will cause it to ice too quickly and cause damage.
Dec 03, 2012 | Bunn Margarita Machine Ultra 2 Slush...
Why can't you use Pepsi or Coke in a Bunn Ultra 2 machine?
in order for the product to slush, it has to be at the right brix level (syrup to water ratio). if it's too lean, it will ice up causing damage. there are also silicon seals that will not do well with carbonation after a while.
Recently bought a used Taylor Shake/Slush Freezer Model 430 to be used for shakes. It was used for aheks in the past and no problems, however, we put it together and the ice cream is too hard. Even...
The Taylor 430 thermistor model has two adjustments a fine adjustment, which is made by turning the knob, and a coarse adjustment that is made by turning the screw in the center of the knob. I suspect you are trying the fine adjustment, which will change the product + or - 2 degrees F. The coarse adjustment will let you set the product temperature between 10 and 30 degrees F.
As far as the clunking, those machines clunk a little. It would do it more if the product was too hard.
You are correct the machine will leak drops into the drip tray, but if it is more than drops, you want to address it. Should be as simple as a new tune up kit.
X39969Tune up kit for most Taylor Slush Machine non Carbonated machines...
If this doesn't help, or if you have any other questions, you can reach me at
Soft Serve Parts Supplies
Mar 15, 2017 | Taylor Ice Cream Makers
Taylor 8756 ice cream machine clogs at face
i need to know where i may go to get directions to put this taylor 8756-22 ice cream machaine back togeather if you can help please e-mail me at johnjohnson1967yahoo.com thanks
Jun 01, 2009 | Taylor 632-33 Ice Cream Maker
Refrigerators Logo
108 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
