Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Ice chute door on maytag refrigerator
When I go and try to get ice, the door to the chute does not open. I have clean the chute and still no ice will come out. The ice machine will dispense the ice into the chute but the door will not open. Any help would be greatly appreciated
    Scholar:
  • 150 Answers
The door is opened by a solenoid. it is bad or it is not getting voltage due to bad control or wiring
Posted on Apr 24, 2008
Outlet of ice tray ices up, also ice on door below ice maker. I clean it and ice is back in less than a week, whether we use ice or not.
What is the model number? Sounds like the ice chute door is sticking open and causing the refrigerator to run all the time while warm air is drawn through the ice chute door opening.
Appliance 911 Sea Breeze
Oct 01, 2015 | Refrigerators
THE ICE MAKER PRODUCES LOTS OF ICE HOWEVER WHEN I PUSH TO DISPENSE ,ICE COMES DOWN THE SHOOT BUT DOOR WILL NOT OPEN TO RELEASE.tHE WATER FEATURE WORKS FINE ON THE FRIDGE .i HAVE REPLACED THE DOOR SEAL BUT...
There is a small motor on the outside of the freezer that you can see if you look up inside the door opening for the water and ice. It may be a silver color and is not very big. On a Whirlpool it is between the ice chute and the water outlet. Also, sometimes the ice chute door freezes shut.
Mar 25, 2015 | Maytag Refrigerators
Underside of ice bin freezes up built up with frosty ice, dispenses no ice. numerous times we have defrosted with blow dryer, removed, cleaned bin, replaced; cleaned out ice that was built up in lower part...
W10224328 Dispenser Door Spring
The chute door is the reason your ice bin is freezing up and also the chute door being open draws warm moist air inside your freezer compartment causing massive amounts of frost and keeps the compressor runing all the time between defrost. You really n eed to get the chute door fixed. What is the correct model number? For the model KSRX25FT dispenser parts click HERE The chute door spring may be broken but you will not know untill you open the dispenser housing. I'm here should you post the correct model number or have questions, Sea Breeze
Oct 17, 2013 | KitchenAid Architect ® Series II KSRX25FT
Door dhute not opening to let ice fall
on the right hand side of the door chute there is a little metal barrel that needs to be attached to the end of the arm that holds the ice door. this is attached to the spring that opens and closes the door chute.
Apr 16, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Ice maker frosts over on the chute
This would indicate a problem with the ice chute door seal. Have it serviced. Air leakage would cause the frost-ice buildup.
Jun 01, 2008 | Whirlpool ED2FHSS Side by Side...
Ice chute door does not open
the solenoid is right beside the ice chute door. there is an arm coming off he door to the side and the solenoid has a stirrup hooked to the arm. you have to remove the trim surrounding the dispenser area to access this stuff. you don't repair the solenoid you replace it. ca. 20 bucks for the part
Apr 25, 2008 | Maytag MFD2560HES Bottom Freezer French...
The ice flap in the door does not open when ice falls down the chute
The door is opened by a electrical solonoid, not by the ice itself. This solonid gets corroded due to moisture, To axcess the solonoid remove water tray remove three torx screws removing trim panel, remove 3 more torx screw holding dispenser module to freezer door two on either sides and one by paddle. Maytag has a kit called a fountain door kit that has everything to rebuild the ice door system,
Jan 10, 2008 | Maytag MSD2454G Side by Side Refrigerator
Maytag side by side Refrig. - Ice maker chute door
problem is in dispenser, check switches and or selenoid.
Jan 05, 2008 | Frigidaire FRS3R5EMB Side by Side...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
362 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
