Question about Muratec Office Equipment & Supplies
When I send a fax afte reserved I get a printed note tha the renote machine is busy, I checked and the remote machine was not busy.the same thing happened yesterday on several attenpts to the same number. My machine manual says M800 M2500
    President:
  • 567 Answers
Hi you should check the settings of the fax machine to see it is correct.
Posted on Jul 29, 2010
  • 7 more comments
  • Earl Fey Jul 29, 2010
    What settings should I check. The machine has been working for years without this problem
  • Hilton Bristol Jul 29, 2010
    Please tell me what type of fax machine you have
    Manual cover says M800 M2500 and it uses special roll paper and has an attached phone,
  • Hilton Bristol Jul 30, 2010
    Try these steps:
  • Check the phone line connected to your fax machine for problems. This is one of the most common reasons fax machines don't work. Connect the phone line to a regular telephone and listen for a dial tone. If you don't have a dial tone, replace the phone cord to see if that was the problem. If that isn't the problem, test the other phone lines in the office. If the other lines aren't working, contact your phone provider to have them fix the phone line.
  • Step 2Look at the electrical cord of your fax machine if the unit won't power on or work at all. Check that the cord is properly plugged into the wall and into the back of your fax machine. If it is, and it still isn't working, replace the cord.
  • Inspect the lamp on your fax machine to see if it is working properly. Fax machines may receive faxes, but not send them if the bulb is burned out.
  • Step 4Open the cover to your fax machine if you are getting complaints that your fax machine isn't sending quality faxes. Do this by pulling on the front panel of the unit. Using a soft cloth, clean out the dust and debris from this front panel. Accumulation of dirt here could definitely be the problem.
  • Step 5Watch for any toner or ink splotches on the inside of your fax machine. If your copies or faxes aren't printing at a high quality, you may have an ink problem. When you shake your toner cartridge, it should shake cleanly and no toner should leak out. If you have a leaky cartridge, it is bad.
  • you can let me know if it work
  • Earl Fey Jul 30, 2010
    How do I get the Bulb out to check it
    Replace a defective fax machine bulb by turning the fax machine over and removing the bottom panel of the unit. Wearing a glove and not touching the bulb directly, remove the old bulb from the fax machine. Screw the new bulb into the machine and replace the bottom of the unit
    where can I buy a bulb
    You can check a supplier of fax machine for the bulb they would advise you which store to buy the bulb from.
    When someone is trying to fax us, it says on their side that it went through but we hear no dial tone and do not recieve any faxes. What can we do to try to fix this? We have to have our fax working as...
    Well first thing is to call your own fax machine from a telephone at your location and make sure that it rings and answers....you should hear the tones in the earpiece of the phone you are calling from. If that works, go to your fax and try to make a "copy" on it to make sure it actually prints onto paper. Then get someone locally with a fax machine to send you a fax...make sure your machine answers and then prints the page out. If it wont print the pages out are the pages going into memory???? Maybe your machine is asking for toner or a drum???
    Sep 09, 2010 | Office Equipment & Supplies
    The fax machine will not faxes, it prints out as busy.
    make sure the cable is in the LINE socket not the TEL socket as this will stop connection..
    Jul 20, 2010 | Brother IntelliFax-2820 Laser Fax
    Canon fax-phone L75 will not send nor receive
    CHECK YOU PHONE LINE IF OK YOU HAVE BAD MODEM CARD
    Feb 09, 2009 | Canon FaxPhone L75 Plain Paper Laser
    Fax Will not send or receive.
    Unplug the power cord for 10 seconds.
    It is not detecting a dial-tone.
    Jan 30, 2009 | Brother IntelliFAX 4100 Laser Fax
    How to send fax from computer ?
    Please follw the below steps:
    To Fax From Your Word Processing Program1. Some software products, such as Microsoft Word, allow you to fax a document without opening your fax software.
    2. Open the document that you want to fax.
    3. From the File menu, select Print. The Print window opens.
    4. Instead of printing to your default printer, look for an option that allows you to Print to Fax. Select this option and click Print.
    5. You will be asked to provide the recipient's fax number and other assorted information as with a fax program.
    6. The fax message compiles, the modem dials. If the connection is made with the other modem, the fax will be sent.
    To Send a Fax From Fax Software1. Prepare the document that you want to fax.
    2. Prepare a fax cover sheet, if desired.
    3. Open your fax software - such as Microsoft Fax or Microsoft Exchangemag-glass_10x10.gif.
    4. Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item.
    5. Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed.
    6. Indicate whether you wish to send a cover sheet.
    7. When asked to attach the file, follow instructions to attach the file that you want to fax.
    8. When ready, click Send. The fax will begin to compile the information and, when ready, will dial the remote fax machine.
    9. When the connection is made, the fax will be sent.
    Thank you.....
    Dec 08, 2008 | Office Equipment & Supplies
    Samsung SF 3200
    The person you are sending to has a busy phone line.
    Call your cell phone from the fax machine to test.
    Oct 24, 2008 | Samsung SF-3200 Fax
    Sendidng a fax
    I have been sending and receiving faxes for over a year on my Lexmark X6100 printer. Now whenever I try to send a fax it will say it is sending the pages but then waits for a redial. After doing the same thing a second time it will print out "remote fax error"
    Aug 11, 2008 | Lexmark X4270 All-In-One InkJet Printer
    Not connecting to fax out
    Do you have a DSL or other digital phone line?
    Jul 10, 2008 | Brother IntelliFax-2820 Laser Fax
    Receive faxes but can't send
    Instead of trying to send a fax try to call the number from a different phone. To see if the receiver is busy all the time..
    Jun 24, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
    Can't send out fax
    the number you called does not answer or busy-you may have reached a number not connected to fax or it is connected and not activated in receiving mode-check the number and call again.
    if you have a message "out of memory"there is no enough memory available to send your fax.press stop/exit print the faxes stored in the memory to delete them then try again.
    Mar 18, 2008 | Brother IntelliFAX 885MC Plain Paper...
    160 people viewed this question
    Top Muratec Office Equipment & Supplies Experts
    Kyocera HP Expert
    Ben
    Ben
    Adorjani Laszlo
    Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
