Question about Cameras
I have an A520 Powershot..I dropped it and jammed the lens..now the lens won't retrack back in.
  • Cameras Master
  • 4,738 Answers
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Apr 25, 2008
My daughter dropped our A520. The power comes on for a second and then shuts down. The lens is stuck open. Is this worth fixing?
I had this problem once. The lens was stuck open and the power would not go on. I took out the storage card and the lens retracted.
Aug 23, 2010 | Canon PowerShot A520 Digital Camera
Lens is stuck about 97% open. The camera will not
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Nov 04, 2009 | Canon PowerShot A520 Digital Camera
Describe hi, i have a canon powershot a520 that was left in someone's purse when she gave it back to me the lens is now sticking half way out and when i push the power button it blinks on for a split...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 22, 2009 | Canon PowerShot A520 Digital Camera
My canon A520 lens cover don't open
lens opens about 25% . Will not close back.
Mar 15, 2008 | Canon PowerShot A520 Digital Camera
Jammed Lense
Jan 06, 2008 | Canon PowerShot A520 Digital Camera
Two different Canon A520 problems.
hey guys. there is no solution that you can do it for yourself. the best solution i can give for you is take it to service centre. here in india we get charged nearly 1800rupees for servicing the lens portions.
Nov 21, 2007 | Canon PowerShot A520 Digital Camera
Replacement parts for canon powershot a520????
I have a "broken" A520 that needs a new LCD. I really don't want to spend another $90 to get it fixed so may be willing to sell it for parts. Let me know. I don't know about any guide for disassembly however.
uncleRx
Oct 03, 2007 | Canon PowerShot A520 Digital Camera
My Canon Powershot SD400 won't turn on and lense won't go back in
Unfortunately the lens assemblies in these compact digital cameras are quite delicate. The drop probably knocked the barrels of the lens out of alignment preventing it from moving. You can try to GENTLY twist the lens back and forth, you may be able to click it back into alignment allowing it to function normally. If the gentle manipulation fails to fix the problem you will need to get the camera serviced by a professional. There are quality repair services on the web who will work on your camera. David Millier Advance Camera Repair
Mar 05, 2007 | Canon PowerShot A520 Digital Camera
Cameras Logo
101 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
