Question about Microsoft Xbox 360 Console
My xbox 360 is giving me three red lights it turns on but after a few minutes it turns off n shows three red lights
    Scholar:
  • 203 Answers
Okay, 3 blinking red lights can have 2 problems.
1: There's a problem with the power supply. Try unplugging the power supply from the wall and the system for 10 seconds, then connect it once more. There should be a little light on one end of the big box thing between the cord to the wall and to the system. Turn your system on and watch the light, if it is green, then that part is okay. Try replacing the wires on either end of the box (or use a friend's which is cheaper ;P). If this doesn't fix it then you have a problem, see 2.
2: You have a hardware issue somewhere inside the console. There's nothing you can really do about this without voiding your warranty. Call Microsoft and get a repair order for it. You'll have to send it off to the them, but if your Warranty is still good, they'll fix it free. If not they will charge you the repair costs. You are of course free to cry softly over the problem, as i did when faced with the red ring of death.
Posted on Jul 29, 2010
Xbox 360 three red lights occasionally
Dave thanks for your question. It appears that your xbox is experiencing over heating issues. Here is a link to an XBOX 360 repair guide for this issue.
Jan 26, 2013 | Microsoft Xbox 360 Console
My xbox ix switching on and shows three red rings and after 5 minutes the brick turn orange and it now has two red rings whay do i do to fix it
Thanks for your question. To fix the 3 red lights what you will need to do is stop the heat getting to the GPU and the CPU and to do this you can use a good Xbox 360 Repair guide or of course you can send it in.
Jan 10, 2013 | Microsoft Xbox 360 Console
Everytime i turn my xbox360 on its flashing red like it the red ring of death
1 Red Light
Your system indicates this error when only the bottom right part of the ring is flashing. When you have 1 red light on the Xbox 360, it is usually associated with an error code you see on the screen, such as the Xbox 360 error code E74.
Searching for this error code online or in the Microsoft support site will give you the description and solution. Usually the problem lies on the DVD drive whether it is the wrong firmware or lacks a chip.
It may also be a hard drive error which can be resolved by taking it out and putting it back in or it can be a voltage error which usually occurs if you have added accessories to it. It is best to research the error code so you know exactly what to do.
2 Red Lights
One of the most common is when two red lights are flashing. No need to panic if you see only see the Xbox 360 2 red lights. Its sole meaning is that the console is too hot and needs to cool down. Power down the system and try again in a few minutes or if possible after an hour or two.
After giving the system some rest and playing in a much cooler environment, you should be back to your gaming in better performance. If the problem persists however, you may need to have it serviced to have the cooling issue fixed.
3 Red Lights
If you see three flashing lights, you are experiencing the infamous Xbox three red lights problem that many other gamers are frustrated with. You may also know it as the Red Ring of Death.
At one point 1 out of every 3 Xbox 360 owners experienced this problem. This is the one error that you do not want to get. This highlights that there is a serious Xbox 360 hardware problem.
Your options are to send your console back to Microsoft for repair or to fix it yourself. Be prepared to spend a nice amount of money ($140 or so) if you are sending your system to Microsoft and you no longer have the Xbox 360 warranty.
If you want to try to fix the problem yourself then you can see reviews of guides that we recommend to show you step by step how to perform the repair.
4 Red Lights
If you have to get any flashing lights on your Xbox 360, pray that this is the one. If the entire ring flashes, it is a minor problem that indicates that the AV cable isn't connected properly or in rare instances, the cable is damaged. Make sure everything is properly connected and replace it if It still doesn't work.
Mar 22, 2011 | Video Game Consoles & Games
Three red lights
Three red lights error occurs when there is a general hardware failure with the Xbox 360. When this error occurs the systems signals it by showing 3 flashing red lights around the power button. There are a variety of reasons speculated why this error occurs.
The most common consensus is that the Xbox 360 has an inefficient design causing it to overheat. The overheating causes other reactions to the parts in the system to malfunction giving you the 3 flashing red lights.
So how do you fix it? Well if you still have your Xbox 360 warranty then you can ship it to Microsoft to have them fix it. Microsoft has extended the warranty to 3 years due to the huge number of problems with the consoles. There are a few stipulations to the warranty, though.
  • Only covers the Red Ring of Death Error. It does not include other types of malfunctions.
  • Applies only to the original purchaser of the Xbox 360. So you would not be covered if you bought your system from somebody else or if you purchased a used version.
  • Must have your receipt or proof of purchase.
  • Be prepared to lose any saved information that you may have if Microsoft decides to send you a replacement system instead of fixing your old one.
  • Prepare to be without your Xbox 360 for up to 4 weeks or longer, although some people have reported receiving them back much sooner.
So if your system is still under warranty and you meet the requirements above then you can send your unit to Microsoft since they do not charge you for the repair.
Dec 23, 2010 | Microsoft Xbox 360 Console
The power bar on my xbox 360 has a red light on it and won't turn on i was playing yesterday just fine and i have three different power cables i have tried and still nothing they all give me the same red...
I CAN FIX IT! There are links that show you how to repair this issue yourself (but they are not very clear and every thing is very fragile inside the XBOX 360) or you can contact me via reply on here and we can discuss the issue further as I recently repaired my XBOX 360 with the same issues and it works better than when was brand new.
Or you can google xbox 360 RRod issues it is a MS defect
Nov 12, 2010 | Microsoft Xbox 360 Console
My Xbox 360 Gets 3 Red Lights Of Death and Then Works Fine
You can fix the 3 lights of death by replacing the x-clamps and the crappy thermal paste. Here is a kit to fix it and it comes with the guide too.
http://cgi.ebay.com/XBOX-360-Repair-Kit-3-Red-Light-Fix-3-rrod-COMPLETE_W0QQitemZ380123627056QQcmdZViewItemQQptZVideo_Games_Accessories?hash=item5881223e30&_trksid=p4634.c0.m14.l1262&_trkparms=|293%3A1|294%3A30
Jul 11, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360
go to xbox.com and the help section and it shows you how to fix it
Jun 26, 2008 | Microsoft Xbox 360 Console
Diagonal white lines...
Thats the first stages of the 3 red lights ,the white lines are vertical sheering caused by the vga chip.Microsoft now give 3 years warrenty for the 3 red light error plus if you have only just had it back from Microsoft then it will have deffo got a year on it anyway.
Jun 08, 2008 | Microsoft Xbox 360 Console
My xbox 360 keeps freezing!!
wrap your 360 in a towel (Completely Covered), turn on the system for about 10 minutes, turn it off, then back on again and and it should work.Although this fix only works fr about three hours it works over and over but the problem you have can also be fixed by replacing the thermal compound on the heat syncs and it should only cost about $5.00 to fix your 360. But my second solution should only be used if the warranty is void
Apr 02, 2008 | Microsoft Xbox 360 Console
Xbox 360 red lights
2 red lights flashing is'nt too bad of a deal. just reposition your xbox 360 to a place where more airflow can get to it. plus, dont have anything that gives off heat near the xbox 360, thats vary important to give it room for cool air. it worked for me
Nov 15, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
57 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
