Question about Apple iPod touch
I did an update on i tunes to 9.0 version then i updated the I pod to the 4.0 and after that the computer will not recognize the i pod. it shows the itunes logo and a usb cord on the screen but i can not do anything. i have done a restore but it comes up with an error message. It worked fine befor the update
How to fix iPad 4 shows iTunes error code 9
Easy Steps to fix iPad 4 shows iTunes error code 9:-
1. Install the latest version of your iTunes.
2. Then, Force your phone to restart: ...
3. Connect your phone to your computer using a USB cable.
4. When iTunes asks you to update or restore, click on Update (not Restore) button to reinstall iOS and keep your personal data.
Read more at Fix iTunes Error Code 9 or Call 1-800-608-5461 iTunes Support Number
Sep 01, 2017 | Tablets & eReaders
I pod is disabled
1. Manual reset by Home key + Down Volume key, this can fix many general iPod problems.
2. You may try this iTunes alternative, I always use it to upload music and video to my iPod once my iTunes can't recognize my iPod, my friends recommend it to me, it's safe and works pretty well, you can also use it to copy music and video from ipod to computer for backup, it's useful when you lost your iTunes library.
http://www.ipod-transfer-copy.com/ipod-iphone-to-computer-transfer-cucusoft.html
3. Update your iTunes to the latest version. Plug in your iPod. If iTunes can't recognize it, then in iTunes in the top left corner click help> run diagnostics. On the box that comes up, check the last two things. Click next and it should identify your iPod. I got this method from Apple technical support. Hope it helps. Contact me if you have any other question. 4. Take the iPod to Apple store, the technical support will help you fix the problem.
Nov 29, 2013 | Apple iPod Touch 4 Metallic Zebra Hard...
How do i unlock my ipod touch when i forgot my password nd i dont have a itunes account
Hi yulilove2000
You will have to create a I tunes account in order to update the bios and drivers.
After you install I tunes to your computer then connect your I Pod to the computer with I tunes running using the data cord.
Then I tunes will sync with your player and then you will be able to update the I Pod.
It will ask you if you want to sync with this computer....you will reply yes.
You can then add all your music, pictures, videos into I tunes and the I Pod will then be recognized by the computer as your souce computer.
Please take time to rate me
Jul 02, 2011 | Apple iPod touch
TUNE TOOLS WON'T READ MY 80GB IPOD BUT USED TO WHAT DO I DO ? TUNE TOOLS MESSAGE IS:(THERE WAS AN ERROR LOADING THE APPLICATION:JAVA.LANG.EXCEPTIO:UNNOWN MHOD...TYPE-102)
By any chance had you recently upgraded your ITunes to ITunes version 9 or higher? Tune Tools used to work fine for my Ipod Classic 80 gig, but as soon as I upgraded my ITunes to version 9, the Tune Tools 2 stopped working, and I got that exact same java.lang.exception error.
If you have updated to ITunes 9, there isn't anything you can do about it.
Jan 25, 2010 | ValuSoft Tune Tools for iPod Full Version...
I pod shuffle of apple-unknown error 1442
This could be a solution you can try. If you do not have a virus program on your pc and you need to get one to protect your computer, download a free version at www.avg.com and do a scan. It updates itself free, but you may also have malware, so you may have to go to www.zdnet.com to see if there's something out there you can download for malware. You can also try microsofts version of defender. Sounds to me like a software issue. Once you are done, reboot your system and try it itunes again, your device should be automatically recognized. If not, look at your device drivers, perhaps there's something running in the background, or a device incompatibility issue. You can have your computer devices updated at www.drdriver.com for free too. Hope this helps. Rose @ jndacademy@sbcglobal.net
Feb 28, 2009 | Apple iPod shuffle MP3 Player
Grays songs in ipod when connected to Computer
You need to set your iPod to update manually, instead of syncing automatically when you plug it into the computer.
To do this, plug your iPod into your computer, and on the iPod info screen that pops up in iTunes when your iPod is connected, click "Manually Manage Files."
You'll now have to click and drag your songs from your library to your iPod, but now you can also play songs on your computer directly from your iPod and delete songs from your library without deleting them from your iPod at the same time.
Hope this helped!
Sep 05, 2008 | Apple iPod MA446LL/A MP3 Player
I pod
Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab.  Then click on the “Repair” button to start the repair process.  Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in.  If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Aug 28, 2008 | Philips GoGear HDD6330 MP3 Player
20GB IPOD
maybe...perhaps try changing your itunes setting
to
"manually update ipod" if it is set to autosync then all tunes in the library which are registered as being on the pod will automatically update. each time you connect the pod the itunes sw will update the pod from the library.
when the pod is connected and auto sync is active if you delete a tune from the lib it will update the pod and delete the same tune.
Apr 29, 2008 | Apple 20gb Ipod Mp3 Player With Click...
Miissing e drive
Try updating or reinstalling iTunes.
Jan 02, 2008 | Computers & Internet
Sansa e250 won't show up in devices!
I had the same issue. Brand new Sansa e250 player. My XP SP2 computer would not recognize it. I updated my Windows Media player to version 10. Bingo, all is working now. I previously had version 9. Good luck!
Dec 24, 2007 | SanDisk Sansa e250 MP3 Player
Apple iPod touch Logo
41 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
