SOURCE: Pairing Mode
I wonder if you all are having the same issue I did. I came here for the same reason, I was unable to make my 510 go into pair mode. Here is what "I" was doing wrong. I would press the call button and THEN press the volume up button, thinking that as long as they were held down at the same time for 3 seconds, and it didn't matter if both where pushed at the same time or not. It matters. Both buttons need to be engaged at the same exact time, not one right after the other like I was doing. Good luck!
SOURCE: old voyager 510
There is no need to reset your old bluetooth device. You should put the device in pairing mode so that it can be detected. once you have that set up you can register it on your old device and your new device. I had my bluetooth device on 3 different phones! You can pair your headsets with more than one phone. Questions, get back to me!
SOURCE: pair plantronics voyager 510 with mac book os x
1. Turn Bluetooth On in Macbook 2. Turn the headset On 3. Press the Up volume and the conversation On/Off key at the same time until the blinking blue lights blinking Blue and Red alternatively 4. In a couple of seconds the Mac will ask for the Authorization Key 5. The Auth key is "0000" (4 zeros) 5. Pairing should now be successful and you should be able to use the PLT510 headset with your Mac. I can
SOURCE: My Plantronics Voyager 510 will not go into pairing mode.
i actually got this to work with my iphone 3G S. i pressed the little black button then saw a blue light flash, and then i pressed and held the + volume button and the call control button until it started blinking blue and red and my iphone picked it up instantly. it did take a couple of times to get the headset to go into pairing though
SOURCE: I have a mingxing A008 phone plantronics bluetooth how to use
how can I set up Jabra bluetooth with MingXing A008 mobile
