Question about JVC C-13910 13" TV
Hernandez030763@yahoo.es I had a JVC c-13910 tv, but it don't have IC Regulator of Power, and don't have written the B+ (Fly). As I don't have diagrams about that TV I don't Know what are its pinout. Its fly's number is qqh0029-001(I need its B+).Its IC Regulator of Power someone took it, it don't exist.
    Genius:
  • 1,019 Answers
Hi Buddy,
I can,t help you out Here.
Televisions are not my speciality. I repair X-Box Consoles-PCs And Laptop Computers. You Might Try Ginko.
He may be able to help you out Here.
Mike @ Compurepair.
Posted on Apr 25, 2008
How to fix problem of jvc crt tv model av-21l31 power ok no video/audio no display with lines coming from flayback
Look at the horizontal output transistor then the fly back transformer.Check ALL the voltages coming from the power supply. One or more of them have to be missing for the audio and video to be gone at the same time.
Sep 24, 2014 | Televison & Video
CAN YOU PROVIDE ME THE NUMBER OF THE REGULATOR IC FOR JVC TV MODEL JVC-AV21WX14?
To which section this IC connected with. Can you provide more details?
May 21, 2013 | Televison & Video
The problem started from a power surge.
You may be on the wrong track here.......fly backs are a common failure,but not because of power surge. Most commonly the problem would be on the primary side of the power supply ,such as the rectifiers and sw mode regulator. If you want to prove it,just un solder the horiz out transistor(q401) and the pin of the flybackit connects to...... and if it still blows fuse ,you need to work on the power supply.......not the horiz/hv area
Jun 04, 2010 | RCA F36665 36" TV
Our JVC AV-32F703 has a black screen when we turn it on. The sound works fine. What could it be? The tv was purchased in Jan 03
try up the screen bottom in the fly back. if yoy see a white horizontal line the tv have a cold solder in vertical ic or is bad.
Apr 14, 2010 | JVC AV-32F703 32" TV
Lost picture and controls
Check first the power of your tv ,maybe theirs sort circuit on the regulator ic ,then replace it with the new one...
Oct 09, 2009 | JVC AV-36260 TV
TV JVC 27530 C
download the instructions manual from here:
http://resources.jvc.com/Resources/00/00/95/YA050Bien.pdf
looks like the power supply is still not repaired.Check internal fuse also
Oct 02, 2008 | JVC AV-27530 27" TV
JVCTV
strf6709a must be the power regulator
May 25, 2008 | LG 42LC2D 42 in. LCD HDTV
The flyback for JVC C-13910 is listed below. Do you have the location number for the IC Regulator?
JVC C-13910 Flyback T1522
Apr 22, 2008 | JVC C-13910 13" TV
Television goes off without turning off
your set needs to be repair by a tech you are having a problem in your power suply which is intermittent.either your hrizontal ic is shorting out, or your regulator or your microchip ic.or the diode that couple the collector of the horizontal transistor with the b+ from the fly back.or check for lose solder in the horizontal output or power supply. good luck
Mar 10, 2007 | Toshiba CZ32V51 32" TV
It sounds but cant' see the imagen
You need to find out why the set is blanking the video. In order of being common: 1. AKB circuit. AKB circuit is seeing a very unbalanced crt and blanks the video. To fix replace the crt. 2. Loss of vertical deflection. 3. Problem on the data or clock lines. If you can change channels and the volume, this is ok. 4. Loss of h-sync return pulse to the micro or jungle ic.
Mar 19, 2006 | JVC C-13910 13" TV
JVC C-13910 13" TV Logo
51 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
