Question about GE 24 in. Monogram ZBD6880KSS Stainless Steel Built-in Dishwasher
After a complete cycle the tub is still full of water. Model# ZBD7920P1OSS
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasherAfter a complete cycle the tub is still full of - 2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Jul 30, 2010
No water going into dishwasher checked supply line its good Frigidaire model fdb635rfr6
Just had a similar problem with my Frigidaire FDB834RFS0 model. Dishes were not getting clean. Noticed some detergent still remaining in the dispenser after completing a wash cycle. Checked the water level during several cycles and noticed it was barely visible in the bottom of the tub. Decided to remove the water supply valve and solenoid to check it, thinking I would probably have to buy another one. Took it apart and found there is a mesh water strainer on the inlet side that was full of bits of junk. Cleaned it out and decided to reinstall to see if it made a difference. Noticed immediately when starting the next cycle that I could hear the water gushing into the tub. The water level rose significantly and the result was clean dishes and no left over detergent in the dispenser.
Jul 31, 2010 | Frigidaire Dishwashers
Fill cycle stops before full
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 03, 2010 | Kenmore Washing Machines
Water is pooling in the wash tub even after the cycle has completed. the next day, the tub is full of water and leaking out the front
Your Mixing Valve (water valve) is not shutting properly.
Replace it to solve your problem.
Thanks for using FixYa!!
Jul 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
HE5 Washer. Water in tub all the time.
your water solenoid is probably not closing completely and letting water by pass. Not sure what your model number is but you can find this part and others at www.Repairclinic.com Good luck.
Apr 20, 2009 | Kenmore HE5
Gentle cycle did not complete leaving water standing in the tub.
Whirlpool downloader washer model number GHW9150PWO
PROBLEM Gentle cycle did not complete leaving water standing in the tub
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water level high when spin/drain cycle begins.
The water level is higher when in the rinse mode; but it should never leak. Examine the interior through the rear, there should be a loose hose somewhere. Or at the filter area. Plug off the mains caution.
Feb 28, 2009 | Kenmore 22932 Top Load Washer
Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Feb 23, 2009 | Kenmore 46462 Front Load Washer
Tub overflow
Remove the hose from the water level switch and blow air through it.
The water level switch air hose has a clog in it.
Feb 22, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag dishwasher MDB9100A---tub refills after cycle completed
Problem is actually a water valve that is near the water inlet. Cost is about 35 bucks to fix unless you listen to the guy on here and pay for parts that you don't need and pay them 20bucks for bad advice. Our total cost to fix this $35 dollar problem was an entire wasted Sat, 2 trips to the appliance repair parts place, $130 for the electrical control board that the "wiz" here said I needed--electronic parts and non returnable so we now have a new one that we didn't need.
Mar 29, 2008 | Maytag MDB9100A Dishwasher
Open Questions:
See all GE 24 in. Monogram ZBD6880KSS Stainless Steel Questions
GE 24 in. Monogram ZBD6880KSS Stainless Steel Built-in Dishwasher Logo
148 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
