Question about Alpine Car Audio & Video
Hi I have just fitted an Alpine CDE113BT Unit into my Citroen Xsara Picasso. After tuning in the presets as described in the manual and using the radio for an hour I was disappointed to find that afetr turning the unit off and on again the preset buttons are all untuned again. I read somewhere about having to cross over a red and yellow wire. Is that the case? regards Chris Legg
  • leggsahoy_ch Jul 29, 2010
    very helpful and quick response. Many Thanks
  • 435 Answers
There's 2 power sources for the head unit. (Yellow and Red wire)
The red wire should be connected to a switchable 12 volt source (turns on and off with the ignition switch) this circuit is for the operation of the head unit.
The yellow wire should be connected to a constant 12 volt source (not switched on or off), this circuit maintains the head units memory and clock settings when the unit is shut off.
Posted on Jul 29, 2010
    Hi Gozer
    I think I understand the problem now and should be ale to fix it in the morning. Many Thanks for that.
    My next question is to do with the remote stearing column control. The Xsara Picasso has such a control in place. Are there any cable adapters available that will connect the REM socket on the radio to the existing control block. If not, is it possible to make one up from parts or do I have to buy a dedicated unit from Alpine?
  • Mike Raatz
    Mike Raatz Jul 29, 2010
    Unfortunately you'll have to use a unit from Alpine or there's another company PAC. The radio connection is universal but the interface with the car is unique, so you'll have to match the steering wheel control adaptor to your vechicle.
06 citroen xsara diesal timing belt change required
06 xsara picasso 2.0hdi 160 000km
06 xsara picasso 1.6hdi 240 000km
this info i read on a software called autodata the reason i put 2 vehicles is because you didnt say which one you have check with the agents or your owners manual
Jul 02, 2016 | 2006 Citroen C4 2.0
When indicator light shows both arrows not single
CITROEN XSARA PICASSO questions and answers
www.roadtestreports.co.uk/cars/citroen/xsara-picasso/qanda/
Results 1 - 40 of 914 - Help and advice on everything CITROEN XSARA PICASSO. ...fitted.. citroen do two variants.. one with pads and one with shoes. ... Hi when I turn side lights on my indicators start flashing and ... Both bulbs are OK, but light is of. ...our 2006 Picasso just wondering does yours go past 50mph if not then it ...Missing: arrows
CITROEN questions and answers - RoadTestReports.co.uk
www.roadtestreports.co.uk/cars/citroen/qanda/
One more thing the clutch is nearly gone but this wouldnt cause the noise. ... My horn keeps going off randomly in my Citroen C1 hatchback car ( 2006 ) when I ..... MyCitroen Xsara Picasso`s air bag warning light comes on but not all of the time. .....box Citroen C3 - two boxes will show, both fit, choose the £48.9 one + £5.00 ...
Jan 11, 2016 | 2006 Citroen Xsara Picasso
To fit gear select cable
disconnect both ends, and cable clamp
replace it.
adjust it.
like FSM shows. (the factory service manual)
May 05, 2014 | 2001 Citroen Xsara
What tool is used to open the head bolts on a citroen xsara picasso
Special tool like Torx key. Use the ones that can be inserted into a size 10mm bolt socket. I think it's size T50.
May 03, 2014 | 2004 Citroen Xsara Picasso
Citroen Xsara Picasso. Cigarette lighter keeps blowing a fuse when I use my sat nav
use the higher fuse. rather then a 15amp fuse, use 20 amp.
that will resolve the issue
Aug 18, 2013 | 2001 Citroen Xsara Picasso
How to fit near side steering rack gaiter on citroen xsara picasso 2005
take off tyre.
undo one nut on steering outer track rod end free it.
then its infront of you
Jun 27, 2013 | 2001 Citroen Xsara Picasso
Back door on citroen xsara picasso wont open
door unit as packed up so you will need to some how remove door card to see not for the faint hearted this one it will need some skill
Feb 16, 2013 | 2001 Citroen Xsara Picasso
How to fit fan belt for 2003 citroen xsara picasso
im trying o find out the same thing ,mine is acitroen xsara picasso,the steering pump went ,so put another one in ,and cant seem to find much info and not 1 photo,did u get any joy ?
Nov 13, 2012 | 2001 Citroen Xsara Picasso
Car Audio & Video Logo
97 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
