Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Washer stops working after 1 minute and an F flashes
    President:
  • 1,382 Answers
The error indicates that there is no water detected entering machine or Pressure switch trip not detected..If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
  • 3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Thank you !!
Posted on Jul 30, 2010
2 Suggested Answers
  • 50 Answers
SOURCE: WASHER RUNS FOR 1-2 MINUTES, THEN STOPS & STARTS FLASHING H/F
can u switch of hte michine at the wall and leave it for 20 mins and turn it on again
Posted on Jan 27, 2009
The washer goes to LE and flashes. Then the washer stops.
Could be 1 of 2 things your washer nds a reset try unplugging the washer leave unplugged for 5 minutes replug start your machine Your drum may be out of line when it starts to wash it jumps off if that's it u will nd to call 4 service
Apr 22, 2013 | Washing Machines
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Mar 10, 2011 | Bosch Washing Machines
Start a normal load then it stops and flashes f 21
Possible Causes / Procedure
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. after 10 minutes plug in and retry.
4. if this does not work you need service.
Apr 27, 2010 | Maytag EPIC MFW9700S Front Load Washer
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
LD flashing
"Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display.
Usual causes are easy to check:
1. Unplug the washer and clean the pump strainer. It is located between the drum and the pump, and will be attached to the drum with a rubber hose.
2. Dump your drain hose into a bucket to remove any build-up in the drain hose. If possible, run an empty load, with the drain hose pointed outside.
Best regards, --W/D--
Aug 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Duet washer stopped during wash cycle.
take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
May 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F2 flashing on display screen washer won't continue cycle????
This means that the drain time has exceeded 8 minutes and the water valves have turned off. After 4 minutes the suds error is displayed then 4 minutes later the F2 error.
Potential causes
1.Check drain hose for kinks or cloggs
2.Check electrical connection at the pump and make sure the pump runs.
3.Check inside of pump for foreign objects
4.If none of the above fixes the machine replace the pump.
Oct 12, 2008 | Kenmore 46462 Front Load Washer
Duet washing machine
f-11 is a motor control unit error.
These codes and more details are printed on the service technician diagnostic manual that is affixed to the inside of the washer's front panel.
Unplug your washer, and unscrew the three 1/4" socket screws at the bottom of the washer. The manual should be taped to the back of the panel, and the code and some recommended procedures will be right inside.
May 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
116 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
