Question about Hayward SAND FILTER, PRO SERIES
I cleaned my Pool filter element and need to precoat it with diaomite earth, how is it done. The chart said I need to use 6 lbs. do I put the earth powder in the skimer?
  • 990 Answers
Yes. Clean your baskets, then with the pump on and the baskets in place slowley put the powder in the skimmer. Ether straight from the bag or mixed in a bucket of water. Just be sure to go slow so it dosen't clog the pump while going through system.
Posted on Aug 02, 2010
Breathing tube clogs within a day or 2 after cleaning. Pool water is clear and clean but psi goes from 10 to 15 in 2 days.
have you done a total clean on the filter? over time DE can build up in the bottom of the filter tank and significantly reduce filter are causing high pressures.
see if you can pull the bottom drain plug and remove the lid of the filter (do this on a shady day or in low light conditions) grids do not like sunlight and will shorten their life. rinse out the filter's base with a garden hose.
OR if the pool is dirty it will take time to clean it you will need to continuously flush the filter until pressures drop
Jun 26, 2017 | Pool & Spa
Tip
Basic Swimming Pool Care
<p>Basic Pool Care Tips<br /> <ol> <li>Test chlorine and pH at least 3 times per week. Have a comprehensive water test every 6-8 weeks at your local pool store. There is generally no charge for this test.</li> <li>Operate pool equipment a minimum of 6-8 hours per day during winter months and for 10-12 hours per day during the summer for greatest overall benefit.</li> <li>Brush the pool walls and floor a minimum of once a week.</li> <li>To prevent damage to pool equipment make sure the water level never drops below the opening of the skimmer.</li> <li>Lubricate backwash valve "O" rings on sand and DE filter four times a year. Lubricate pump lid "O" ring periodically with Lube specifically designed for use with swimming pool equipment.<br /><br /><img src="water_1.jpg" /><br /><br /></li> <li>Test pH and add muriatic acid as indicated to maintain pH between 7.4 - 7.8. Never add more than 1 pint of acid at a time and wait at least 1 hour between treatments. Always add muriatic acid by dispersing into pool water opposite the skimmer and disperse as far away from the wall of the pool as you can safely reach. Use care not to drip acid or any chemicals on deck as it will cause deck etching and staining. Do not pour acid over steps, benches, or pool light. Make sure water is circulating.</li> <li>Clean waterline tile with cleaner a minimum of once a month during peak season.</li> <li>One month after initial pool start-up, add stain and scale inhibitor on a regular basis.</li> <li>Always follow manufacturers instructions on product labels.</li> <li><b>NEVER ADD WATER TO CHEMICALS</b> - Add chemicals to water.</li> <li>Always wait one (1) hour between adding different chemicals unless otherwise directed. <ul> <li><b>Filters:</b> <ul> <li><b>Sand Filters:</b> Backwash once per week</li> <li><b>DE Filters:</b> Backwash once filter pressure increases 8-10 psi above your "clean pressure" noted at start-up.</li> <li><b>Cartridge Filters:</b> Need to be taken apart and elements need to be cleaned once filter pressure increases 8-10 psi above your "clean pressure." This cleaning should be done at least a minimum of twice a year.</li></ul></li></ul></li></ol>
on Dec 21, 2010 | Pool & Spa
3620 hayward de filter earthe coming back to pool
take filter apart examine all the cloth elements if torn or ripped replace and that should fix your problem
Jun 23, 2014 | Hayward EC-40 DE Pool Filter with pump
De is going back into pool and not stiching to the fingers
there is a tear in a element or not put together correctly
Jun 01, 2012 | Hayward EC-40 DE Pool Filter with pump
I have an XP2 in my 6 year old above ground spa. Recently the breaker keeps flipping after about 15 minutes of use and the pump motor is very warm. Is the pump done??
You have a gage on your filter? Anywhere on your system? I would suspect yout system should run at about 18 to 28 lbs PSIG when clean and go up about 10 lbs PSIG when it needs to be back washed.
Aug 19, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Water leaking out the top
Here is a copy of the users manual for these pool filters. It has detailed illustrations about how the filter should be put together.
http://www.backyardcitypools.com/images/hayward/perflex-system-manual.pdf
Jun 21, 2010 | Hayward EC-40 DE Pool Filter with pump
Pool filter return keeps stopping
If you have cleaned the fingers in acid you may have to replace the socks on the fingers.
Jul 21, 2009 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
I have an intex chlorinator and an intex 24' x 48" round pool. I added only 250 lbs of salt, but the table said 290 lbs. I never got a "low salt" reading. When the water level got low I added water and...
high chlorine can cause problems too it will give false readings for your ph and alkalinity.
The most important thing to remeber is that there is a sequence to follow.
First buy a test kit for salt about 11 bucks for 10 tests. you need to have the ppm's at 3000
if it is to high drain 20% water re-fill and filter/curculate for 6 hours then test again. once at 3000 then go for your chlorine it should be between 1.0 and 1.5 with a test kit now with those 2 in line go for ph adjustment ph should be as close 2 7.6 as possible. Ph will cause more problems like cloudy water or algea more than anything else.
another thing you need to realize is that the intex salt system sucks. Once you set it for the # of hours to chlorinate you are basically guessing as to what is needed. Yes there is a guidence chart as to hours to run but it is over kill and lets too much chlorine be generated start with 3-4 hours of generating but remember also that at 4 hours generating that is nowhere near enough filtering
you will need to shut power off get it out of sleep mode and continue to filter
on avberage a pool should be turned over 3 times a day my pool 7000gl and the 2000gph all in one intex salt pump needs run at least 10 hours a day alone without the chlorinator
my pool only 18' so with your total gallons it will be longer
one last thing to consider is that when in chlorine generating mode the filter slows down because of all the electronics. You can not hear it happen but if you put your hand in front of the discharge you can tell
Jun 27, 2009 | Intex Automatic Salt Water System for ...
D.e. earth pool filter returning dirt to pool
The flow tubes inside the filter canister are torn and letting dirt pass. The repair is simple and can be done by someone with a few hand tools. Download the manual for the filter here:www.haywardnet.com/products/Manuals/pdfs/manual9.pdf
You'll only need to replace the ones that are ripped, and the cost runs about $3 - $5 each. Search around on Google for a supplier or try a local pool dealer.
Jun 08, 2009 | Hayward EC-40 DE Pool Filter with pump
Hayward SAND FILTER, PRO SERIES Logo
102 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
