Question about kawasaki Full Suspension Mountain Bike Men
Need to know how much air to put in rear suspension bike ride hard
    Problem Solver:
  • 12 Answers
Until it is hard except on a hot day because the heat will cause it to expand and pop like mine did.
Posted on Jul 29, 2010
2007 Yukon Denali XL autoride suspension light comes on intermittently
Would need to know what DTC'S - diagnostic trouble codes are stored in the module for the autoride suspension . Hooking up a professional type scan tool ,looking at input data to the module etc... Looking at a wiring diagram an testing electrical circuit's using a DMM - digital multi-meter . Reading how the system works ,what all involved in making the system work . This is how a professional Tech would go about diagnosing this .
The automatic level control (ALC) system maintains a desired rear suspension position under all types of towing, hauling and loading conditions. The following components are involved in the operation of the ALC system:
• Air line tubing--Pressurized air from the ALC compressor is pumped to each of the rear shocks via air line tubing.
• Air drier--Pressurized air from the compressor is run through a drier containing a moisture absorbing chemical preventing water accumulation in the rear shocks.
• Compressor--Supplies pressurized air to the rear shocks
• Compressor motor relay--The relay supplies battery positive voltage to the ALC compressor motor.
• Pressure sensor--The electronic suspension control module (ESCM) module provides a 5-volt reference and low reference to the ALC pressure sensor. The module receives the signal voltage that is relative to the air pressure applied to the rear shocks.
• ESCM--Controls the ALC system and electronic suspension control (ESC) system and detects failures in both. The module monitors inputs from the position sensors, and pressure sensor to determine when to raise and lower the vehicle to trim height as the vehicle is loaded or unloaded. The module limits pump activation to 255 seconds to prevent thermal damage.
• Exhaust valve--An electric solenoid activated by the ESCM to vent air pressure from the rear shocks.
• Left and right rear suspension position sensors--The module provides a 5-volt reference and low reference to all 4 of the body-to-wheel suspension position sensors. The sensors send the ESCM a signal voltage that is relative to the rear suspension ride height
• Left and right rear shock absorbers with internal air chambers and dampers--Dampens the rear suspension and maintains trim height depending on the air pressure applied.
Nov 04, 2017 | 2007 GMC Yukon XL Denali
Trying to find a wiring diagram for air compressor. Rear air ride is out compressor not running at all checked fuses just replaced relay .
I know that you are trying to fix that air ride, but i put these replacement springs on my 93 towncar. Fixed the compressor problem (eliminated it) and cost a whole lot less. The install is kinda hard if you've never dropped a rear end before. Need a good tool set, a couple jacks, and jack stands to get it done. Check it out. Even having a mechanic install them would be cheaper than replacing a compressor.
http://cgi.ebay.com/ebaymotors/LINCOLN-TOWN-CAR-AIR-SUSPENSION-SPRING-CONVERSION-KIT-/180707393835?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1993%7CMake%3ALincoln&hash=item2a1300012b
Aug 26, 2011 | 1990 Lincoln Town Car
I have a 1987 cbr 600r Hurricane and i need to know how much air to put in the front forks?
The front forks are adjustable to the type of ride you want. First, set the rear shock to the setting you want soft, medium, or hard. There should be max pressure information in your owners manual and on a sticker on the front forks. Typically the most pressure that can usually be put into a Honda front fork is around 14 PSI. Add, carefully, 10-12 PSI using a hand or foot bicycle pump with a gauge on it. You will probably find this way too stiff. Be careful not to put too much pressure in the forks or you will pop the seals and have to replace them.Then with the bike loaded the way you are going to ride (soft for comfort or hard for two up riding) bounce on the seat. What you want to feel is the front and back suspension dropping at the same time. This is how racers set up there motorcycles for hard cornering. If both the front and rear of the cycle drop together you have an easier time controlling the bike during extreme maneuvers. Since the front is usually stiffer than the back(you added pressure there) slowly bleed the pressure out of the front fork tubes until the the front and back drop together while you are bouncing with the bike loaded the way you are going to ride. Now you are set up for extreme riding conditions. Soft or hard that is how you set up all motorcycle suspensions by balancing the the amount of front cushion/pressure to match the back cushion/pressure.
Jun 30, 2011 | 1987 Honda CBR 600 F(1)H
I have a early 1980's honda 750 need to know how much air pressure the fork's hold, or need to put in them.
You do not have to put any air in the forks. There was a sticker telling you maximum pressure on the bike. It may still be there. Maximum pressure is not more than 14 pounds. You will never need more than 7 or 8 pounds. First set the rear shocks for a hard or soft ride. Then holding a bicycle foot pump with a pressure gauge on it in your hands , give it one pump (do not go over 10 or 12 pounds pressure). Now bounce on the seat and bleed pressure out of the forks until the front and rear shocks drop at the same time. Your bike suspension is now set up correctly for riding.
Sep 26, 2010 | 1987 Honda VF 750 C Super magna
Tax disc where to fit/rear suspension pressure setting, 1 & 2 up
I cant help with tax disc, but I can help with the setting of the suspension. The ideal setting for the suspension is to set it so the front and back drop together. If the back is too stiff and the suspension compresses in a corner the front is more prone to breaking loose causing the worst kind of slide . If the front is too hard and the suspension drops in a corner the rear end is more prone to breaking loose. This is not as bad losing grip on the front end, but if word gets out nobody will ride with you as a passenger ever again. Set both front and rear shocks near maximum pressure. Now sitting on the bike with it loaded the way you intend to ride bounce on the seat causing the suspension to drop. Now bleed air out of the front or rear shocks until both the front end and back end of the bike drop together. This is your stiffest safe ride setting. If you start with no pressure in the system and add air until the bike drops with front and back in unison, this will be your softest safe riding setting. Riding single or double requires two different settings. This is how racers set up sport bikes for extreme riding.On a Goldwing you will only need the correct settings for extreme emergency conditions , but of course that is when it has to be predictable and it has to be right. Setting it up correctly will also make cornering through the hills much more enjoyable.
Jun 10, 2010 | 1999 Honda GL 1500 SE Gold Wing
Problem with the left rear air ride shock
you will have to reconfigure the rear suspension, best talk to a spring and suspension shop
May 28, 2010 | 1992 Oldsmobile Ninety Eight Regency
Air suspension light came on I turned the car off light went off, then I noticed the rear end of my car was low. What could that be?
It is your air ride suspension. It could be the air bags, the sensors, compressor, wires and many other things. What I did was bought an after market coil spring suspension and converted it from the air ride suspension. The air ride is lovely but costly. It is hard to diagnose that air ride suspension without spending a lot more money then you want. I suggest getting an after market converter kit, but I would make sure it has the sensor plug so that your warning light on your dash goes out....otherwise it will be on forever!
Jan 10, 2010 | 2000 Lincoln Town Car
Got the bike used with 8500 mi & no owners 2001 fxdxt
yes, the rear shocks use air pressure to adjust the ride to exactly the way you like it. Only problem is that you don't want to go to your local fuel station and use their pump. You should have gotten a small hand pump with the bike. If not, you can get one at your local dealership or order an aftermarket pump. It usually takes somewhere around 5 psi for most people, I think. The reason I think is that I've never owned a air suspension bike and never asked anyone how much air to put in the system. Some bikes even have air front forks. Seems the air fitting is in the end of one of the grips or something.
Jan 04, 2010 | 2001 Harley Davidson FXDXT Dyna Super...
VERY LOW REAR END
rear suspension ride leveler mslfunction. Check Air compressor function.
May 27, 2009 | 1992 Lincoln Town Car
Honda front strut air pressure
fork psi should'nt exceed 9psi. fork air valves are best used for removing air. spring preload should be adjusted to abtain the correct sag (1'' on most street bikes)
May 08, 2009 | 1982 Honda CX 500 B
kawasaki Full Suspension Mountain Bike Men Logo
71 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Marvin
Marvin
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
