Transfer belt is ripped. where do i go for a new one.
    President:
  • 2,571 Answers
Google the make and model, try amazon
Posted on Jul 29, 2010
How to deal with error code E00012-001of canon irc5870
E012 occurs if the machine cannot read the patch when trying to calibrate color. The main causes are- 1) dirty patch sensors, located on the right side of the machine when you open the right door, just above the transfer belt-typically a off white colored plastic piece. you would have to slide to the rear and blow (3) holes out with canned air. 2) ripped belt- would have to be replaced. 3) fatigued developer causing patch to be read incorrectly. 4) faulty motor on Image transfer Unit.
Jun 07, 2014 | Office Equipment & Supplies
Damage of Transfer Unit
Are you changing the whole belt unit or just the belt with the same belt frame.
Some times the frames get bent and that eventually starts sliding the belt to one side causing it to rip. If you are changing the whole belt unit and it keeps on doing it then you might have some parts either broken or damaged.
Take the Transfer unit out and with a flash light make sure the Belt lift assembly is not bent and it easily raises the belt up and down.
Take out the Image unite(make sure you protect them from the light) and put in one at a time to make sure you are putting them in correctly, make sure they light up evenly.
One last thing you might want to look at is the erase lamps to make sure they are not bent and are still in place.
Hope this helps......
Iteminconline
Nov 24, 2013 | Xerox Phaser 7760/YDX Laser Printer
C13c8
C13C8 A new installation is not detected when a new Transfer Cleaner Unit (Image Transfer Belt Unit) is installed.
When a new transfer belt unit is installed in a machine an internal component on the transfer belt unit changes state; this now indicates that the transfer belt unit is used
http://kmcopierservice.blogspot.com/2011/02/how-to-reset-transfer-belt-bizhub-c203.html
Apr 10, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Lexmark x502 printer shows tray 1 missing
hi...........
pls do the following :-
Tray Missing: Insert Tray Tray 1 and/or Tray 2 is missing. Insert the specified tray(s) into the printer. TR Belt Life: Replace Transfer Belt The transfer belt is exhausted. Install a new transfer belt. TR Kit Life: Replace PQ Kit The transfer roller and transfer belt cleaning roller are exhausted. Install a new transfer roller and a new transfer belt cleaning roller. TX Comm Error An outgoing fax transmission error has occurred. Resend the fax. Warming up Wait for the message to clear....
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 29, 2011 | Lexmark C532n Color Laser Printer
Hello - I have a CLX 3160 printer. The black imaging film above the imaging unit seems to have ripped in one place. Is this fixable please?
It is the transfer belt. I don't think there is a supplier of just the belt itself. You must replace the transfer belt assembly. The part number is JC96-03611A.
Jan 18, 2011 | Samsung CLX-3160 All-In-One Laser Printer
Paper jammed in printer & when we pulled it out a black film sheet was ripped. What part is this?
it could be either fusing belt or transfer belt ripped.its a major problem. only a ricoh technician can fix it now.
Jan 04, 2011 | Ricoh Aficio CL3500N Laser Printer
En toshiba e-3511 sale codido de error CEE0
CEE0: Transfer belt position detection abnormality (normal speed):
The home position of the transfer belt cannot be detected.
This likely means that your transfer belt has gotten ripped. There are reflective strips on the transfer belt that tell the copier what position the entire belt is in before copying, and when the transfer belt gets ripped it causes the machine to not be able to find these strips.
You will need to replace the transfer belt and it would be a good idea to change the belt cleaning blade as well.
Aug 30, 2010 | Toshiba E-Studio 3511 Color Copier
Sc481
SC 481 is a belt mark detection error. The transfer belt on the photoconductor unit has a rip in it. Replace the Photoconductor unit.
Apr 09, 2009 | Ricoh Office Equipment & Supplies
Adding Songs from CDs onto my MP3 Player
If you're using Windows, then use Windows Media player to rip your music into WMA. If you don't want to do that, use CDdex to rip your music from CD to MP3. The problem probably lies in whatever program your using to rip your music. To your player. http://cdexos.sourceforge.net/
Jul 15, 2008 | RCA TH1101 MP3 Player
Ripping and transferring dvd to my creative zen w 60 gb mp3/4 player
use a program that rip DVDs and CDs, download it from www.download.com after you download rip the DVD and transfer it to your MP3. Hope this helped you
Feb 18, 2008 | Creative Labs Zen Touch MP3 Player
18 people viewed this question
jasbo
jasbo
