Question about Apple iPhone Smartphone
I phone when someboby rings my phone it doesnt ring it shows that they are ringing but i cant ans it than when they stop ringing i can use the phone
    Problem Solver:
Check baseband with BBINFO,They must be : firmware 1.1.4.- 04.04.05G and boot loader3.9_M3S2.
Method reflash with i tunes(firmware link
http://george.zjlotto.com/index.php/iphone-firmwares/
iliberty+-dfu mode-iTunes restore with dwnl firmw.before then:-iliberty+, check jailbreak,activate-unlock downgrade bl(before in iliberty+ download all payloads) and go for be end.grey wifi edge....can fix wit payload from iLiberty+
Posted on Apr 25, 2008
Phone doesnt have dialing tone, cant make a call also when we ring home its goes to engaged tone
This means that your phone line is short circuited somewhere.
The technical name for it is Partial line Lockout.
Try unplugging anything connected to the phone line, including modems, fax machines, house alarms etc (as faulty equipment can cause this), then try ringing home again. If it now rings, plug things in 1 at a time and ring each time to see what is causing it.
If it is still an engaged tone with everything unplugged, then the short circuit is on the phone line in the street and needs to be repaired by your telephone company.
Oct 11, 2014 | Lands Phones
Hi, When the phone rings into the office my phone is th eonly phone that doesnt show on what line the call is coming in to. One of the other phones is fed directly from mine and it shows it perfectly
This is probably something that requires a technician unless you're familiar with ICD groups. The lines appear on buttons and your phone probably lights with a solid red light to show the line is busy, but you can't pick it up. By default, ICD code 600 is ring group 1, but you have to get access into SYSTEM programming to add your extension to it. The ring condition, immediate, no ring, or ring delay x rings is also part of the programming.
Carl
Sep 30, 2009 | Panasonic KX-T7630 Corded Phone
Stop ringing at certian phones when outside calls come in.
http://dstech1.com/programming-line-ringing/
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist's extension to Immediate Ring and the lines at the users' extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users' extensions -with the receptionist providing backup -set the line at the users' extensions to Immediate Ring. Then set the line (or lines) at the receptionist's extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist's extension.
Programming
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
Jan 09, 2009 | Lucent PARTNER18 Corded Phone
M7310 phone not ringing audibally
If the internal calls dont ring, then there is something with the extension. When a call is ringing the phone, press the UP VOLUME. Chances are that someone accidentally turned the ringer all the way down.
Let me know if that doesnt work.
Nov 05, 2008 | NorStar Meridian M7310 Phone
Caller ID
Since it appears by default, I'm guessing that the phone is not ringing. It has to ring to display CID. You need to make sure that it is part of an ICD group with Immediate ring.
Carl
Sep 03, 2008 | Panasonic KX-T7630 Corded Phone
Phone doesnt ring only vibrates
I had the same problem - on the left hand side of the phone (not the screen) if there is a red dot showing you have switched your phone to silent. Click the switch and your phone will ring
Jun 16, 2008 | Apple iPhone Smartphone
GE 28111 does not rings
are you using voip like from a cable company or a ata bridge? mine doesnt ring when using ANYTHING other than the landline, but caller id will show
May 09, 2008 | GE 28111 Cordless Phone
No sound when phone rings
Look at the ring volume. Make sure it's not at zero. Let me know if that works.
Jul 28, 2007 | Motorola Mobility RAZR V3
Unsupported File, Ring sytle
is it all in your memory card data,, doesn't show up in media aside from mp3?
Jan 25, 2007 | Motorola Mobility RAZR V3
Apple iPhone Smartphone Logo
141 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
