Question about Garmin GPS
The Garmin 1340 works fine, but dont works in my pc!!
The Garmin 1340 works fine, but dont works in my pc, he reboot in loop when i plug an usb cable. I do the hard reset and nothing happen... I need ERASE the maps and hard reset dont do this..
The maps are in local memory of GPS.
  • pablothiele Jul 30, 2010
    I download the drivers herehttp://www8.garmin.com/support/download_...
    Install and after 10 reboots... THIS WORKS!!!
  • 268 Answers
Download and install the software driver from Garmin.com
Posted on Jul 30, 2010
Testimonial: "Thanks Man!!! "
  • bagh1329 Jun 20, 2011
    That solution doesn't work for me, I need help ! I installed USB drivers, myGarmin agent communicator, but nothing.
    My Garmin is detetected by the PC, when I connecte it, it opens, but I reboots in loop everytime.
    Can you help me? Thanks a lot.
Garmin nuvi 40 goes into usb mass storage mode when pluged to charge
I updated my Nuvi 40 with the latest software and it will not reboot into GPS mode with the usb cable connected. It used to work. I have figured out how to get it to charge with a standard USB cable:
1) Power it on.2) Press the battery icon for 8 seconds - it will enter TEST mode.3) Plug in your USB cable from the PC to the Nuvi - the screen will change to say charging.4) Press the power button 3 times rapidly - it will say Charging across the screen and it will go dim and then dark.5) To wake it up and use GPS mode while charging simply press the power button 3 times rapidly, again.
Works Great!
Nov 15, 2011 | GPS
Reboot the Nuvi 360 to "Mass Storage Mode"
1. Connect Nuvi3xx to PC vis USB Cable for 7xx to go into
mass storage mode.
2. Slide Power Switch to the right (LOCK Position)
3. Click the "Safely Remove Hardware" icon in system
Tray on PC (Lower Right)
4. Click on "Safely remove USB Mass Storage Device -
Drives(x:and y:)" x: = mass storage for the 3xx and y: = the
SD card if one is installed
5. WAIT for 3xx to Boot UP.
6. After 360 Boots UP slide power switch to center
position
Sep 30, 2008 | Garmin n vi 360 GPS Receiver
Garmin 1340 - can't use while charging the battery
This is either a oh doh! kind of thing or a setting or battery issue. On some models the gps is detected as a usb storage device when connected on the usb. If this is the case you won't be able to use it normally but you can copy files or update it. You can use the software to 'talk' to it and change settings. If you look at my computer you should see something like drive X: Garmin GPS or drive X: USB storage device. You may see two one for the main device and the other for the SD card.
It also sounds like it could be that your battery needs replaceing or its not getting enough power to run on. This is a bit strange as it should just shutoff when the battery is drained not lock you out. On a good battery it should run about 3 hours on a overnight charge. If it is less than that duration then it does need replaceing. Have you tried plugging its and its usb onto a differant computer? It is possible that either the usb setting has the power limited or the usb is an older type that doesn't provide enough power. Normally it should run and charge while connected to the usb cable.
Apr 03, 2010 | GPS
My Garmin gets stuck on the garmin screen saying loading maps. I have tried to the reboot option of holding down the right corner, power on, and then click yes to erase maps, however when i click yes,...
Borrow a USB cable to plug it into a computer. I just had this issue with the nuvi 1300, and that was the only way to fix it.
Holding the power button for 10-15 seconds would attempt to restart it, but it would just get stuck on the "Loading Maps." section.
I was able to fix it by simply plugging it into a PC's USB port, where the unit started up for purposes of data transfer. Then I unplugged it, and it restarted properly.
Mar 28, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin nuvi 660 in PC Sync mode even it is not connected to PC USB or AC power supply. So the GPS is useless since it is not even in navigation mode. Any idea how to solve it?
Here's a work around. 1) Plug the USB cable in and let enter Sync Mode as usual. 2) When the Garmin unit is in Sync mode, unplug the USB cable. 3) The Garmin unit will start to exit Sync mode, at which time, IMMEDIATELY plug the USB cable in again. 4) If you plugged in the USB cable in time, notice the Garmin unit will remain out of the sync mode.
Jul 04, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin 200w goes into usb mass storage mode when pluged to charge
Steps:
1) Disconnect the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi will reboot, but remain in GPS mode!
Jun 08, 2009 | Garmin nuvi 200W GPS
My garmin nuvi 200 worked fine the first 3 times
Connect your GPS to your computer with the USB cable and this will charge the GPS internal battery. Of course your computer will have to be on during the charging process. After a few hours turn on your GPS and see if it now works. If it now works then go to http://www.garmin.com and register the GPS. While you are on line also download the latest USB drivers for your computer and install them. When you reboot your GPS should be properly connected to the computer for Operating system downloads etc.
Apr 07, 2009 | Garmin nuvi 200W GPS
Problem with Garmin Nuvi 200
hold the battery icon for 8 seconds, which will take you to the test screen then plug in the charger then exit This works on a nuvi 200w.
Aug 15, 2008 | Garmin nuvi 200W GPS Receiver
Windows XP will not recognize Garmin 200W
I had the same issue. I would plug it in and it would recognize the device then it would disappear.
What I did to solve the problem was to first turn on my Gamin 200w. After it was finished loading maps then I plugged in in to the usb port. My machine recognized the device without any problems. I am running Windows Vista Home Premium. Hope that helps.
Jul 25, 2008 | Garmin nuvi 200W GPS Receiver
Unit doesn't work with vehicle power cable
if you are using the USB cable, that won't work. You must use the bracket plug. the USB cable will charge the unit and you can't use it while it's charging. If using the USB, the system thinks you are either charging the unit or connected to a computer. This is a design flaw.
Jul 04, 2008 | Garmin nuvi 200W GPS Receiver
GPS Logo
265 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
