Question about HP OfficeJet 6110 All-In-One InkJet Printer
Fax not sending
Dear Experts!
After sending Fax showing Result =OK..But Fax not reached there, and also not coming.
I am waiting your positive Reply,Please send Solution as soon as possible,
Hanny..
  • Anonymous Apr 26, 2008
    you did not send any solution to me? please send soonly......?
User guide states I need a 2 copper phone jack connector. I need 50' cable (not available in 50" apparently). My closest phone jack is 37' from my cable and electric outlets where have all the equipment set-up. I have no where else in the house to set up. Wireless jacks are too slow, so I am told. Is there a way to make the four into a two, or can we fool the fax into working with a four copper connector?
Posted on May 05, 2008
  • Jean Gonzalez May 05, 2008
    sorry this was supposed to be a question not a solution
  • 40 Answers
Are you able to make copy...If yes..
Printer needs to be resetted.
Turn printer on...Disconnect power cord on the back of printer..
Then press & hold # and 6 key simultaneously while connecting power cord.....
& system will display reset or off...
Then check after alignment....
Nisar
Posted on Apr 30, 2008
  • Sheikh Nisar
    Sheikh Nisar May 27, 2008
    Yes fax can work with 4 prong cable if the dial tone is detected.
Fax problem with mx432, I get an alarm sound on the last page i am sending and it tells me to eject the page
it might be a laser printer, these are thermal printer, they sometime overheat and flash false error messages
for the noise you can check the condition of the paper rollers
Dec 07, 2013 | Canon PIXMA MX432 Wireless Office...
Fax Result E-3) 3)
On the report where it shows the E-3 error, it should have a legend further down the page that shows what each error means. I think E-3 is "line busy," but check that legend to be sure.
Apr 29, 2010 | Ricoh Aficio 450 Copier
What does COM-E mean when we try to send fax's and the transmissions has this written on it instead of OK.
It means "Communication Error".
The result might be twofold:
- the fax didn't reach it's destination because of communications error (any kind)
- the fax did reach it's destination, but part of it may be unreadable or distorted, or some pages of a multi-page fax did not go through.
In many cases, what the device perceives as an erroneous transmission, is perfectly readable by a human. Therefore it's good to call the recipient and ask if the fax is readable and if all the pages were received.
Nov 13, 2009 | Sharp FO 1460 Plain Paper Thermal transfer...
My fax confirmation result says GN. What does
This mean the fax was not received on the number you send it to.It will show OK on the report if it was send.
Jun 25, 2009 | Canon L220 Plain Paper Laser Fax
FAX received full of black stripes
If you are using upper tray to send the fax than kindly open the fax gently and clean the lens with some cotton and spirit and than try to send the fax you will get the best result. to open the fax unit gently refer the user manual or this open by lifting it up side and you can see the lens inside it so clean the same ok.
Dec 22, 2008 | HP LaserJet 3050 All-In-One Printer
Fax machine stoped receiveing fax
First, check your fax's phone line. Put a regular phone on it and check for dial tone and line noise. If the line is dead or noisy, this will cause a problem.
You can also try dialing your fax number from another phone and see if the fax unit picks up the line and starts initiating communication. (sounds like modem noises)
Jul 30, 2008 | Brother MFC-7820N All-In-One Laser Printer
Fax unable to receive and send.
Some basic troubleshooting tips are listed below to help determine the cause.
Check the following items :
Ensure the phone cord is plugged directly from the wall jack, into the back port of the fax machine marked "Line", "To Wall Jack", or with a wall jack symbol
Remove any other device from the line such as splitters, credit card machines, or telephone answering machines and retry.
Turn Error Correction Mode (ECM) off ,
For turning off ECM > press set up > press ok >go to advanced fax set up by using the arrow key > press ok > press arrow key go to OFF > press ok .
After these steps > try to send a fax to undermentioned number , once it is sent u will recieve a confirmatory fax in return as well .
self confirmatory no for fax 1 888 473 2963 .
or u can try to send a fax to a different local number as well.
Thanks
Apr 25, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Fax nightmare!!!
If you have a BT line and use the 1571 answering facility , when you have a message waiting the dialling tone changes from a constant tone to a split tone. This is to let you know that you have one or more messages waiting.
In order to get the dialling tone to revert to the constant tone you have to deal with the waiting messages in accordance with the options provided i.e Save, Listen Again or Delete. BT say the Split Tone is to let subscribers know when they have a message waiting. This should resolve the Fax problem.
It certainly worked for my phone/fax system.
Good Luck
Geowilmil
Nov 28, 2007 | Pitney Bowes 9920 Plain Paper Fax
HP OfficeJet 6110 All-In-One InkJet Printer Logo
56 people viewed this question
Seeker5211
Seeker5211
