Question about Sony Playstation 3 (PS3) Console
My HDMI output port on the PS3 has broken (when I plugged in the cable it pushed against the wall and there is visible damage to the port). Is there any alternative connection that would still give me good quality on blue-ray and streaming on my tv? Help! Thank you in advance.
  • samsunjek Jul 29, 2010
    I was told that when watching movies (blue ray) on the tv, streaming from netflix, and HD in general through component connector using the PS3, the quality is visibly different. You don't think so? Thank you in advance!
    Sure- thank you for the response!
  • 435 Answers
If your HDMI connector is broken the next best video option is a componet AV cable. This cable is an optional cable SONY sells for the PS3. It plugs into the AV muti out connector port, which is right next to the HDMI port.
This confirguration will require running separate audio cables.
Posted on Jul 29, 2010
  • Sony Master
  • 11,800 Answers
Component (YPbPr) RCA connectors will provide almost the same image quality if you get a decent cable.
  • Azrael SRL Jul 29, 2010
    No. With a good quality cable the image will be practically the same as the one on HDMI.
How do i get my hdmi to work for my ps3 system
Note: How to reset video output settings
If you are attempting to change to an HDMI cable from a different video cable or if the video output settings do not match those required for the display in use, the screen may stay black. If the screen stays black for more than 30 seconds, you may need to reset the video output settings of the PS3.
To reset video output settings:
  1. Turn the PS3 system off by holding the Power button on the front of the console till you see the power light turn red.
  2. Then hold the power button on the front of the console for at least five seconds until you hear a second beep to turn the system on again. The video output settings will automatically be reset to the standard resolution.
[TOP]
HDMI Cable Installation
Interactive Video Tutorial
Click below for an interactive video walkthrough on connecting your PS3 to your television or display device (including HDMI).
alt="Click to play tutorial">
[TOP]
Minimum Requirements
  • PlayStation®3 computer entertainment system
  • SIXAXISTM wireless controller (and USB cable)
  • AC power cord
  • HDMI cable1 (sold separately)
  • TV or display monitor with HDMI port and capable of displaying picture in HD resolution
  • Updated system software installed on your PS3
    Visit PS3 System Software Update to download and install the most recent version.
  • TV "Input" or "Video" channel for the HDMI port
    You need to know the TV "Input" or "Video" channel for the HDMI port on your TV. For instance, if your TV has multiple "Input" or "Video" channels, (i.e., "Input 1", "Input 2", "Input 3", etc.), you will need to toggle through each "Input" channel on your TV until you find the correct channel that displays the HDMI picture. This is important to remember, especially if you do not see the HDMI picture after you connect the cable and configure the PS3 settings. Please refer to the TV instruction manual for more information.
[TOP]
Instructions
  1. Before you begin installation:
    • Turn OFF the PS3TM system using the [MAIN POWER] switch (in the back)
    • Unplug the AC power cord from the electrical outlet
    • Turn OFF and unplug the TV
  2. Connect one end of the HDMI cable into the [HDMI OUT] port on the back of the PS3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
    alt="line drawing of HDMI connection">
  3. Plug in the AC power cord by connecting one end of the AC power cord into the [AC IN] port on the back of the PS3 system and the other end into an electrical outlet.
    alt="line drawing of AC power cord">
  4. Press the [MAIN POWER] switch on the rear of the system. A red light should appear on the front of the system indicating power is available.
  5. Turn on the PS3 by pressing the touch-sensitive [On/Off button] on the system front. The red light will turn green, indicating the PS3 is now turned on.
    Note: The blue light will also appear on the front of the system if you have a disc inserted.
  6. Plug in the TV and turn the power on. The PS3 should detect the HDMI display device automatically. When prompted, "Do you want to output video and audio using HDMI?", select YES and press the alt="X button icon">button. (You may need to press the PS button on the center of the SIXAXISTMcontroller to enable the controller first).
  7. The next screen will ask, "Do you want to automatically switch to the optimal setting?" Select YES and press the alt="X button icon">button.
  8. On the next screen, the PS3 will display the maximum resolution capable on the display (i.e., 1080p). The screen will display, "Do you accept the setting?" You will have 30 seconds to confirm your answer.2 Select YES and press the alt="X button icon">button to save your settings. You have now completed the HDMI installation.
[TOP]
Feb 15, 2015 | Video Game Consoles & Games
When my son plays his PS3 after a while the screen goes blank and the message: check signal cable appears. His PS3 is connected to tv with an HDMi cable and the cable that fits into the AV with the three...
Try these steps:
1. Before resetting cables, make sure PS3 is turned off using the main power switch on the back.
2. Unplug the power cord of the PS3 and TV from the wall socket.
3. Connect HDMI cable to HDMI Out on back of PS3
4. Connect HDMI cable to HDMI Input port of the TV
5. Plug the PS3 and TV back in to the wall socket
6. Turn the main power switch on the back of the PS3 on.
7. While the PS3 in standby mode(red light on) hold down the on/off button on front of system until the system goes into standby mode again. (So the light cycle would go red light-green light-then back to red. This will ensure you held down long enough to reset video output settings.
8. Turn on the PS3 and once the system finishes powering up, the video output settings will automatically reset.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jonathon_2815d94e62f0ea08
Mar 02, 2011 | Sony Playstation 3 (PS3) Console
PS3 HDMI - Sony Bravi KDL-40V2000 Problem
  • Have your ps32_bing.gif in standby mode (red light).
  • Now, press andhold the power button in the front down. Your ps3 will beep twice. Letit go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
try this
May 08, 2010 | Sony Playstation 3 (PS3) Console
HDMI picture is saturated in the wrong color
The problem is generally the cables, period. If there is a condition whereby the cable was bent, kinked, overheated, or the end damaged in any way, this problem can exist. Many times when a cable is attached to the device, it is cross-threaded or left loose. If the contact is not 100%, you can experience this condition. I suggest that you obtain NEW cables and connect them tightly and firmly in place. This should eliminate the problem, UNLESS the male connection on the device/s have been compromised.
Jan 14, 2018 | Philips SWV6813-17 HDMI 3-Way Switcher
I plug my ps3 into my laptop useing the hdmi cabble.. but nothing pops up . how can i play my ps3 on my pc screen?
The HDMI cable on your laptop is most likely an output. If the computer does not say installing drivers directly after plugging your PS3 into the computer than it is most likely an output. Try using the HDMI from your laptop to your TV to confirm this. If the computer does not say installing device drivers right when you plug your PS3 into it that means it is not recognizing it, most likely because that port is for output.
Feb 24, 2010 | Sony Playstation 3 (PS3) Console
Hd port on back broke need to reset video to use av cables any help???
Press the power on the PS3 for 5 seconds (in standby mode) till it beeps thing to reset the graphics output
May 29, 2009 | Sony Playstation 3 (PS3) Console
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Hdmi
I can't be exactly sure without more information, but it sounds like you ps3 is outputting from another port. My ps3 originally was outputting from the component/composite cable port so in order to use the hdmi output I had to do a soft reset. That makes the ps3 sense what cable is plugged into it and automatically output through that port instead of using whatever is the saved setting.
With your ps3 turned on hold down the power button for a few second until it beeps and flashes 3 times (should be about 5 seconds). You might have to try it a few times to get it to work, but you should get picture and be able to adjust the settings on the ps3.
Dec 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
70 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
